Retrofitting a Deckel FP5NC
- Thank you received: 5909
16 Jun 2022 00:29 #245236
Replied by tommylight on topic Retrofitting a Deckel FP5NC
What does the "5/7" refer to in other pages?
16 Jun 2022 13:59 - 16 Jun 2022 14:10 #245266
by gernoff
Replied by gernoff on topic Retrofitting a Deckel FP5NC
It's an interim thing. My intention is to get it running w the existing PLC to reverse engineer the shift sequence before trying to convert to LCNC. The nice thing is that because the system is so modular, I should be able to pull out the PLC (Deckel calls it the SPS) and transplant LinuxCNC in its place.
Last edit: 16 Jun 2022 14:10 by gernoff.
16 Jun 2022 14:03 - 16 Jun 2022 14:05 #245267
by gernoff
The 5/7 is a reference to page and column where the other end of the wire goes. So in the pdf above the PLC is shown on page 5.
Last edit: 16 Jun 2022 14:05 by gernoff.
16 Jun 2022 14:07 - 05 Jul 2022 18:21 #245269
by gernoff
I bought a solid state relay board to isolate the outputs from the FP5NC so I can test to see what the outputs are doing. Hopefully have an idea of what the system is doing by the end of the weekend.
Addendum: The solid state relays was a bad idea. Inconsistant on actually 'closing'.
I have a 8 channel mechanical relay board on the way.
Last edit: 05 Jul 2022 18:21 by gernoff. Reason: New info
05 Jul 2022 18:24 #246672
by gernoff
Started a dedicated thread to discuss modifying the gearbox .comp for a FP5 machine:
forum.linuxcnc.org/10-advanced-configura...-gearbox-comp#246671
Moderators: piasdom
Time to create page: 0.103 seconds
