Pokeys
- juanelo1221
08 Aug 2017 01:21 #97153
by juanelo1221
Replied by juanelo1221 on topic Pokeys
This is the file PokeysLib.h on /usr/include
How can I be sure it work?
Thank you.
Thank you.
- juanelo1221
08 Aug 2017 02:13 #97155
by juanelo1221
Could be the problem the version of Linux CNC?
Thank you so much.
Thank you so much.
08 Aug 2017 09:20 #97166
Probably not, but if youa re using a LinuxCNC version that still uses "comp" rather than "halcompile" then I would strongly encourage upgrading anyway.
Instructions here: linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
The following user(s) said Thank You: juanelo1221
08 Aug 2017 17:39 #97195
by fixer
- juanelo1221
09 Aug 2017 16:42 #97244
by juanelo1221
Ok,I think I've got it!
Yesterday I was testing the system. thinking first in the update I moved my debian wheezy to debian jessi and afterwards tried to update linuxcnc.Everything seemed right until I tried to open my-mill then a linuxcnc error appeared. I thought the issue was because I had created the file in the older version so I created a new one but had no success. Desperate and a little upset I made an afresh installation of debian wheezy, I updated cnclinux and was able to open up the file.
I went back to do all the steps Fixer stated from page 1 and connected the Pokeys in windows to know the serial number. In the file my-mill.hall I wrote loadusr pokeys, ran the linuxcnc and was now able to see the pins. I shut down linuxcnc and now in my-mill.hall I wrote pokeys.0.devSerial 66258 save file and try to open linuxcnc send me an error:
I change the code loadusr pokeys and pokeys.0.devSerial to custom.hal and show me an error, if I put the loadusr pokeys in my-mill.hal and pokeys.0.devSerial66258 in custom.hal linuxcnc run fine, and pokeys.0.err are false and pokeys.0.alive start blinking. Is this procedure correct?
I tried to use estop with pokeys to test but i did not get it work, in custom.hal I wrote net estop-ext <= pokeys.0.in-52 it dont send me errors and in HAL configuration the pin 52 show :
Owner Type Dir Value Name
7 bit OUT FALSE pokeys.0.in-52 ==>estop-ext
Thank you so much for your help, have a nice day.
Debug file information:
./my-mill.hal:7: parameter or pin 'pokeys.0.devSerial' not found
13 Apr 2018 01:44 #108923
by JR1050
Hello, I have followed the instructions on the very first page of this topic and have had success until i tried to compile with the gcc compiler using the following commands
pi@raspberrypi:~ $ gcc -Wall -Os -g -I. -I/usr/include/libusb-1.0 -I/usr/include -L/usr/lib/ -L/usr/lib/arm-linux-gnueabihf/ -lPoKeys -lusb-1.0 -I/usr/realtime-3.4-9-rtai-686-pae/include -I. -I/usr/realtime-3.4-9-rtai-686-pae/include -I/usr/include/i386-linux-gnu -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=0 -fno-math-errno -funsafe-math-optimizations -fno-rounding-math -fno-signaling-nans -fcx-limited-range -mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os -o pokeys ./pokeys.c -Wl,-rpath,/lib -L/lib -llinuxcnchalth
gcc: error: unrecognized command line option ‘-mieee-fp’
the very last line above I am getting a gcc error, any ideas what is causing it and how to get it working. thanks
13 Apr 2018 12:20 #108940
bugs.debian.org/cgi-bin/bugreport.cgi?bug=588960
Leads me to believe that the answer might be to leave out that modifier in your architecture.
Time to create page: 0.265 seconds
