7i95 default HAL file
31 Mar 2021 01:26 - 31 Mar 2021 11:15 #204161
by craig
7i95 default HAL file was created by craig
Does anyone have a correct default 7i95 HAL file? I'm trying to configure my 7i95 with the default encoders.
The Mesa hardware is great stuff, I chose it for my Harig CNC II Surface grinder NC retrofit.
Last edit: 31 Mar 2021 11:15 by craig.
31 Mar 2021 22:57 #204327
by Trab
Replied by Trab on topic 7i95 default HAL file
Hi.
Did you start with a HAL file from here?:
forum.linuxcnc.org/27-driver-boards/37894-mesa-7i95
I am also currently trying to get my 7i95 running. But i am also very new to Linuxcnc and would be glad to have a default file aswell.
02 Apr 2021 12:52 #204493
by craig
Replied by craig on topic 7i95 default HAL file
I will use Pncconf to generate a HAL file for a 7i96 and go through and edit it from there. When I get the file working I'll share it with you. I just have to go back and read through a bunch of the forum posts to see what to change.
29 Mar 2022 18:07 #238634
by Muecke
Replied by Muecke on topic 7i95 default HAL file
-- DE --
Hallo,
haben Sie ein Standard HAL erstellen können?
Das andere Thema ist sehr lange da brauch eich ein weile zum Lesen
-- EN --
Hello,
have you been able to create a standard HAL?
The other topic is very long because eich need a weile to read
Hallo,
-- EN --
Hello,
29 Mar 2022 22:49 #238674
by BigJohnT
Replied by BigJohnT on topic 7i95 default HAL file
I have a 7i95 Configuration Tool
gnipsel.com/mesa/
I'm in the process of rolling them all into one.
JT
gnipsel.com/mesa/
JT
Time to create page: 0.127 seconds
