Error instalation
15 May 2022 15:16 #243021
by BigJohnT
Creating a Configuration for 7i96S was created by BigJohnT
I just pushed a new version of my
Mesa Configuration Tool
which includes support for the Mesa 7i96S card.
Included in this update is a check for the proper version of Mesaflash and a reminder about what version of LinuxCNC you must use with the 7i96S.
It also provides support for the inmux pins which in addition to in not it has a debounce in slow.
This update has been tested on a 7i96S.
JT
JT
15 May 2022 15:18 #243023
by BigJohnT
Replied by BigJohnT on topic Creating a Configuration for 7i96S
Oh I forgot to mention the ability to load the same configuration at startup by checking that option before building. That takes advantage of the new Preferences file that the tool creates.
You can also turn off the check for Mesaflash if you don't have it installed and won't be flashing a card. I hate nag screens...
Getting UpTown.
JT
Getting UpTown.
JT
17 May 2022 12:27 #243145
by BigJohnT
I just completed adding support for the 7i96S to my Mesa Configuration Tool and tested the configuration on my 7i96S.. I need to spend some time on the documents now.
JT
JT
19 May 2022 12:42 #243338
by BigJohnT
If you purchased one of the 7i96S Proto boards don't forget to invert any inputs.
JT
JT
The following user(s) said Thank You: hoffb77
20 Jun 2022 01:50 #245463
by hoffb77
Replied by hoffb77 on topic Creating a Configuration for 7i96S
I installed MesaCT and was successful building a functioning Axis interface on a 7i96s.
Proto boards? What constitutes a proto board or is the current revision the prototype? Is there a thread I missed?
Thanks John, I really like this tool.
20 Jun 2022 02:33 #245464
Replied by PCW on topic Creating a Configuration for 7i96S
There were a few proto boards sold as a marked down special (8 I think)
These need the isolated input polarity inverted
Production boards do not
20 Jun 2022 02:57 #245467
by hoffb77
Thanks for the info. I got a configuration going using the MesaCT and the Pncconf on 7i96s+7i73. I got the Pcconf up faster but the MesaCT was closer to final product. I did get an error. The MesaCT build did not create a sserial,hal. I did manually and all was well. I did have the box checked.
Awesome tools. Love the 7i96s!
20 Jun 2022 19:41 #245493
by BigJohnT
Upload your MesaCT ini file if you still can.
JT
JT
21 Jun 2022 13:33 #245534
by hoffb77
The following user(s) said Thank You: BigJohnT
21 Jun 2022 15:14 - 21 Jun 2022 15:15 #245540
by BigJohnT
Apparently I got side tracked and forgot to finish up converting the smart serial build section... thanks for bringing that to my attention.
Download a fresh deb and reinstall and it should build smart serial cards for all in one boards. I'll work on motherboard/daughter board in the morning.
File > Download Deb
JT
File > Download Deb
JT
Last edit: 21 Jun 2022 15:15 by BigJohnT.
Time to create page: 0.123 seconds
