Homing help needed
25 Mar 2011 21:37 #8088 by jhtitan
Homing help needed was created by jhtitan
OK so I am trying to set up EMC again.
I have everything working except for homing.
when I hit the Home all button everything moves away from the homing switches.
I have homing/limit switches on X and Y (just some micro switches Normal close)
and I have a touch plate for Z homing.
I re-wired the X and Y switches so that they are separate. X switches on pin 13 and Y switches on pin 15, touch plate on pin 12.
movement is set from 0" to 48" on X and Y and from -3" to 3" on Z
I have been using the free version of Mach 3 for a while now but my drawing have been getting more complicated and the 500 lines of code limit has begun to be too limiting.
I am sure I am just missing something simple but for the life of me I can't figure it out.
Jon
25 Mar 2011 23:59 #8094 by andypugh
Replied by andypugh on topic Re:Homing help needed
Put a - sign in front of the home-search-velocity in the INI file.
27 Mar 2011 00:24 #8133 by jhtitan
Replied by jhtitan on topic Re:Homing help needed
OK one more question, how do I get it to back off my touch plate after homing Z instead of dragging it across my table? In mach 3 I could just jog Z while it homed the other axis.
Jon
27 Mar 2011 01:57 #8136 by jhtitan
OK scratch that last question, I got that figured out. I had some of the settings wrong for my touch plate and Z axis. everything works smooth there now.
I am however getting an error on start and I can't seem to find any reference to it anywhere.
"Unexpected realtime delay: check dmesg for details"
anyone got any hints on what that might be?
Jon
27 Mar 2011 09:46 #8144 by Rick G
Replied by Rick G on topic Re:Homing help needed
Probably a latency problem.
Double check your latency test, perhaps for a longer time.
wiki.linuxcnc.org/emcinfo.pl?TroubleShooting
Rick G
27 Mar 2011 12:29 #8156 by jhtitan
Thanks for the link. I was having another problem with my video card driver already, was unrelated I thought, will try different drivers as suggested.
Thanks again.
once I get this fixed then its time for some test cuts.
Jon
