- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
29 Jan 2017 16:22 #86911
by Rolquin
Replied by Rolquin on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Hi there many thanks for all your help.
I'm using Debian , but the Screen looks pretty similar. Only difference , when I'm going to the application menu , either way when I select Setting or System the sub menu is the Synaptic Package manager. I can not find Package manager.
And yes i have been asked for a password, under the Synaptic , but the option for the check mark is not active.
I know your post its related to Mint , as I'm a newbie not sure if its a better option by now stay on Debian.
Thanks.
Thanks.
- cncnoob1979
- Topic Author
- Thank you received: 75
29 Jan 2017 16:59 #86914
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Have you tried to check build dependencies yet?
See if it works without the hassle of enabling repositories. I bet Debian is enabled by default.
Just skip the step of enabling source repositories. Continue from there.
Run the configure ( ./configure uspace) in Debian depending on what guide your following.
30 Jan 2017 07:55 #86952
by Joco
Replied by Joco on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
Post #1 worked like a charm for me and that's doing it on a Core2Duo iMac.
Nice and clear instructions - well done and thanks.
- cncnoob1979
- Topic Author
30 Jan 2017 13:18 #86964
by cncnoob1979
Glad it helped you! You're welcome.
04 Feb 2017 17:27 - 04 Feb 2017 17:28 #87300
by jtc
Replied by jtc on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Today I have time to test this tutorial, work great
I'm using linux mint 18.1 cinnamon 64bit
I'm with a 2560x1440 resolution on on board graphics(msi h97m-e35). the latency could be better but at least I can get a decent resolution.
Two minor bugs for now, Axis starts minimized, and no shortcut for linuxcnc on the start menu, next time I compile linux I will "make install menus" and see if it solves this.
João
João
Last edit: 04 Feb 2017 17:28 by jtc.
- cncnoob1979
- Topic Author
04 Feb 2017 17:39 #87302
by cncnoob1979
Replied by cncnoob1979 on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
There is a fix for the menus issue. If you read at the bottom of the post it tells you how to get the menu to show.
Glad you found the tutorial helpful!
Thanks!
Thanks!
14 Feb 2017 08:17 #87945
by Reinhard
Replied by Reinhard on topic Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
at debian add-apt-repository (for highlab.com) does not import the key.
So I had to issue these commands too:Then the apt-get update succeeds without errors.
wget http://highlab.com/rtai/2017-01-10/dists/archive-signing-key.gpg
apt-key add archive-signing-key.gpg
The following user(s) said Thank You: cncnoob1979
16 Feb 2017 02:43 #88021
by cut2cut
Replied by cut2cut on topic Complete HOW-TO Linux Mint 18.1 32/64 PREEMPT with RIP or build a .deb
I'm having an issue getting past one of the very first steps of POST 1. When I run the Synaptic Package Manager I am not seeing a way to "check for removal" the two items you suggest that need removal : virtualbox and ndiswrapper. For instance "virtualbox"'s only option available is to "Mark for Installation". Can you provide more detail as to how these two items are to be removed ? Or if they are not installed, perhaps they do not need removal anyway ?
Also, later when I get to the point of selecting the "Fully Preemptable Kernel" in the Processor types and Features section there was no option to select a "fully preemptable Kernel". Perhaps this was due to using the 64bit Mint installer instead of the 32 bit version you used ? Now, I am starting from scratch with a fresh install of the 32 bit version of Linux Mint but have yet to get past the above issue with regard to removing virtualbox and ndiswrapper. I think I'll try anyway, without removing those two (uninstalled) items but would like this addressed so other "noobs" can benefit from my early frustration.
Jake
Jake
- cncnoob1979
- Topic Author
16 Feb 2017 02:46 #88022
by cncnoob1979
Hey!
If they are not installed then no worries. In the end it would not hurt either way, on my box it throws an error. If these packages are not in your installation it is safe to ignore. It will not fail the building process.
Let me know if you have any more questions or issues!
16 Feb 2017 03:01 #88023
by cut2cut
Thanks for the fast reply. Ok, I've ignored those items and moved on to the Xconfig. Sadly, bumps in the road here too. You wrote in bold letters :
"CAUTION: You MUST at the minimum select "Fully Preemptable Kernel" in the "Processor Types and Features" section"
Well, I do not see an option for a Fully Preemtable Kernel in the processor Types and Features section.
Perhaps it is not available due to my specific hardware ? Any ideas ?
Jake
Jake
- General
Time to create page: 0.242 seconds
