- General
- Installing LinuxCNC
- Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
Thanks for the fast reply. Ok, I've ignored those items and moved on to the Xconfig. Sadly, bumps in the road here too. You wrote in bold letters :
"CAUTION: You MUST at the minimum select "Fully Preemptable Kernel" in the "Processor Types and Features" section"
Well, I do not see an option for a Fully Preemtable Kernel in the processor Types and Features section.
Perhaps it is not available due to my specific hardware ? Any ideas ?
Jake
I had this problem to, There is a non graphical version of this command that does let you get to the settings. I don't really understand why , but sometime xconfig showed what I wanted, other times it didn't
I think I used make menuconfig
This link lists the options
www.linux.org/threads/the-linux-kernel-c...-kernel-part-1.4274/
- Thank you received: 5909
and that link was informative too. Much appreciated. Was getting a little frustrated already !
Until the next time
Cheers,
Jake
using "make menuconfig" instead of "make xconfig" worked great. Thankyou. It was a bit hard to see that there are subdirectories, but once that was evident I found the preemptive kernel option and check marked it.
Until the next time
Cheers,
Jake
Glad that sorted it for you Jake.
uname -a
- cncnoob1979
- Topic Author
- Thank you received: 75
NAME
uname - print system information
SYNOPSIS
uname [OPTION]...
DESCRIPTION
Print certain system information. With no OPTION, same as -s.
-a, --all
print all information, in the following order, except omit -p
and -i if unknown:
-s, --kernel-name
print the kernel name
-n, --nodename
print the network node hostname
-r, --kernel-release
print the kernel release
-v, --kernel-version
print the kernel version
-m, --machine
print the machine hardware name
-p, --processor
print the processor type (non-portable)
-i, --hardware-platform
print the hardware platform (non-portable)
-o, --operating-system
print the operating system
--help display this help and exit
--version
output version information and exit
manpages.ubuntu.com/manpages/xenial/en/man1/uname.1.html
For instance, I was using the apt-get update command and didn't realize I needed to add the sudo command. Thats truly a beginner mistake, eh !. Lesson learned, when an error comes back " permission denied " its probably because I'm not logged in with superuser privileges. Solution, get that permission by using the sudo command !
Ok, now its onto the next task.... getting linuxcnc to talk to the Mesa 7i76E.
Jake
Jake
Jake, that is the easy bit!
www.linuxcnc.org/docs/html/drivers/hostmot2.html
and then
linuxcnc.org/docs/html/config/pncconf.html
Jake
I don't want to hijack the thread, but now it appears I need to install drivers for the Mesa 7i76E and then I'm told to use pncconf to configure it.
and then
Jake
You do not need drivers or anything, you need the second tutorial from this thread, after that you can run pcconfig to configure the card.
- General
