Installing LinuxCNC 2.9 or Master on Linux Mint 21
18 Jul 2022 13:49 - 18 Jul 2022 19:23 #247667
by Samuelx
Replied by Samuelx on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Thank you for this easy installation guide. Beginer like me got it up and running.
Last edit: 18 Jul 2022 19:23 by Samuelx. Reason: more info
18 Jul 2022 14:05 #247669
by scotth
Replied by scotth on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
I spent Sunday installing Mint 21 on the system. Using Tommylight's instructions, everything went fine. It worked so well, I tried it with MX21, and it worked also.
Latency looks ok, no problems with Sim.
Having the extra drivers for Linux helps a lot.
- ChironFZ16
- Thank you received: 10
21 Jul 2022 07:52 #247916
by ChironFZ16
Replied by ChironFZ16 on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
21 Jul 2022 19:55 #247985
by mgm
Replied by mgm on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
Maybe that helps
linuxcnc.org/docs/html/hal/comp.html
- ChironFZ16
22 Jul 2022 06:24 #248007
by ChironFZ16
- ChironFZ16
22 Jul 2022 08:01 - 22 Jul 2022 08:01 #248010
by ChironFZ16
Last edit: 22 Jul 2022 08:01 by ChironFZ16.
22 Jul 2022 10:14 #248018
by JT
Replied by JT on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
I can't seem to figure out how to remove the generic kernal, remove one another one shows up...
JT
JT
- Topic Author
- Thank you received: 5923
22 Jul 2022 16:07 #248050
Replied by tommylight on topic Installing LinuxCNC 2.9 or Master on Linux Mint 21
JT, use synaptic, slect what you want to move, it will select another to install so say ok but remember what exactly it is istalling, then just uncheck that offending kernel and continue removal.
- Topic Author
22 Jul 2022 16:09 #248051
Dev version
ftp.de.debian.org/debian/pool/main/l/lin...00863908-4_amd64.deb
Can not check, on a cab to airport.
22 Jul 2022 20:24 - 22 Jul 2022 20:27 #248070
by JT
I tried that several times and synaptic keeps installing another different generic kernel... it's really strange.
I'm giving Debian 11.4 a whirl to see what it does... it at least recognized my motherboard NIC so that's better than 11.0.
JT
JT
Last edit: 22 Jul 2022 20:27 by JT.
Time to create page: 0.433 seconds
