Forum Header
ini file
10 years 9 months ago #69327 by sandman92k
ini file was created by sandman92k
Can you see all the config settings in a ini file????
10 years 9 months ago #69332 by cmorley
Replied by cmorley on topic ini file
no - there are some only used depending on optional criteria.
What are you really trying to do?
Chris M
10 years 9 months ago #69347 by sandman92k
Replied by sandman92k on topic ini file
I was trying to keep from blowing my head off..
I bought a probotix electronic package and was told it was turn key just install and go, that was BS.
so they gave me a cnc file, but they have it locked up so you can not go in and modify the config on it, you can only look at the ini file.
so i was hoping i could see the config file setup in the ini to get a base.
but at this point i am so fustrated and pissed off i am just going to step away, It makes me so mad when people (salespeople tell you one thing and then when they get your money its a different story)
thanks for the help
10 years 9 months ago #69355 by cmorley
More then likely the INI was not built using a configuration wizard.
The INI is the file to edit in that case.
Sorry your having problems, but it _can_ be worked out.
Chris M
The following user(s) said Thank You: sandman92k
10 years 9 months ago #69357 by sandman92k
I think part of the problem is the electronics package i got did not come with any info and i can not figure out what it is set at, the other problem is the info on linuxcnc is vague and does not go into any details about where and how to find these settings in the config so you can properly set it up.
10 years 8 months ago #69447 by andypugh
Replied by andypugh on topic ini file
All the configuration is either in the INI file or the HAL file(s).
Start with the INI file, and see which HAL files it loads. Then work through the HAL files and see what information they read from the INI.
You should be able to figure out the parallel port configuration from the HAL file.
But: It might be better just to describe your problems here. We are more likely to be able to help than probotix.
Time to create page: 0.236 seconds
