- Thank you received: 4
hardware and settings:
DM542A from longsmotor
SW 1-3 OFF (3.00 A/RMS; 4.20 A/Peak)
SW 4 OFF
SW 5 ON; SW 6 OFF; SW 6 ON; SW 7 ON (800 Pulse/rev Table)
DB25-1205 BreakoutBoard (BoB)
Nema 23 Longs Stepper Motor 23HS9430 (1.8 deg/step)
Base Information:
Machine Name: Leadshine WanTai Axis configuration: XYZ Reset Default machine units: MM Step Time: 2500 ns 5000 ns Step Space: 2500 ns 5000 ns Direction Hold: 10000 ns 2500 ns Direction Setup: 10000 ns 2500 ns One Parport Base Period Maximum Jitter: 30.000 ns
Axis X:
Motor steps per revolution: 200.0 Driver Microstepping: 4.0 Pulley teeth (Motor:Leadscrew): 1.0 : 1.0 Leadscrew Pitch: 4.0 mm / turn / Umdrehung Maximum Velocity: 20.0 mm / s (1200 mm / min.) Maximum Acceleration: 100.0 mm / s Home location: 0.0 Table travel: -1.0 to 720.0 Home Switch location: -6.5 Home Search velocitiy: 1.5 Home Latch direction: Opposite
I milled a rabbet 720 mm long, but the rabbet is only 717 mm long, so the machine lost 3 mm. Maybe this is a mistake in my setup.
May be not, if you are using too offsets.The distance between 2 points is always the center of the bit, right?
pulse longer than 2.5μ...
and direction 5μs at least
