Forum Header
Chinese TS 3040 LL Set
10 years 4 weeks ago #81195 by Soltan
Hi!
I bought a Chinese 3040LL TS 4-axis cnc handset, but unfortunately I could not get nowhere data sheet which must be the basic settings.
I would like to arouse life under Linuxcnc. The YouTube video is setup, but I do not understand much English, just to set basic values and values on the menu PnCConf Wizard in the Wizard menu StepConf to the text. To do so, please help.
10 years 4 weeks ago #81221 by andypugh
Replied by andypugh on topic Chinese TS 3040 LL Set
Do you have any information about the handset at all? You are not giving us much to go on. How does it connect to the PC?
10 years 3 weeks ago #81249 by Soltan
Replied by Soltan on topic Chinese TS 3040 LL Set
Hello!
The only thing that I know that this type I've described, the Dongda Electric Manufacturer's, parallel port connected to the computer. I tried the manufacturer's website to download the timer values for the machine but could not find.
There are up on the youtube video. This is the link to it:
10 years 3 weeks ago #81250 by andypugh
I might have become confused by your original message. I thought you were trying to connect a control pendant "handset" whereas I now suspect that you have a 4-axis CNC machine?
Have you tried copying the numbers from the video into Stepconf on your machine?
10 years 3 weeks ago #81251 by Soltan
Yes there is a 4-axis machine, unfortunately, fairly badly I speak English.
I will try to give the numbers in the video on my machine but my my my vezérője blue give a picture of him. I do not know how much control in the video is different because there have been some changes in it, I hope you did not change the control itself. Now the youtube hit pretty much where I look at them to try it on my PC settings and will be in touch.
10 years 3 weeks ago #81331 by grump
Replied by grump on topic Chinese TS 3040 LL Set
I have the same machine and it works as I would expect after playing with the settings to get the best performance.
I am not saying it's perfect or right but it works very well.
Not sure I understand your problem but if it helps here is my ini file.
File Name: 4_axis.ini
File Size:2.67 KB
Time to create page: 0.121 seconds
