Forum Header
Parallel port not working
10 years 7 hours ago #82316 by ax650
I've went from 10.04 Lucid to wheezy and linuxcnc 2.7.7. Now my parallel port is not working. I'm using a Sherline cnc mill with Sherline controller. I have checked the bios menu the parallel port is enabled, base i/o address is 378,mode is 378 and interrupt is irq7. Are these the correct setting if not what are the correct settings. I have tried searching but cat seem to find the answer.
Norm
10 years 5 hours ago #82318 by andypugh
Replied by andypugh on topic Parallel port not working
What did you change? Was this just an update of LinuxCNC on the same OS, or did you reinstall everything from scratch?
10 years 5 hours ago #82320 by ax650
Replied by ax650 on topic Parallel port not working
All new from scratch.
10 years 5 hours ago #82321 by Todd Zuercher
Are you using the motherboards built in parallel port, or an add on card?
Are you using your old config files copied over from old to new?
What version of Linuxcnc were you running before when it was all working?
10 years 5 hours ago #82322 by ax650
Motherboard parallel port Didn't copy old files I was using 10.04 lucid now all new computer and wheezy new install.
Norm
10 years 5 hours ago #82323 by andypugh
Do you still have the old config files? They should be a good starting point.
Time to create page: 0.064 seconds
