Forum Header
wiring schematic for G0704 with C41 and C10, in case anyone else needs this.
9 years 5 months ago #92725 by fmfchop
So I compiled some drawings into one form as well as confirmed some of the wiring with some others who have this setup already.
Anyhow, here's where things go. (This is probably not very useful for most, but if I had found something like this a few weeks ago it would have saved me a WORLD of hassle.)
9 years 5 months ago #92726 by fmfchop
And one for home switches and e-stop.
I need to learn more about the soft limits that linux has.
Do you guys definitely recommend running a - and + limit switch on each end of the 3 axis?
Or just a home switch? (Obviously these can double as - limits or + limits if needed, quite easily.)
9 years 5 months ago #92741 by Todd Zuercher
There are lots of options for setting up home and or limit switches with LinuxCNC. Your best option will depend on how many free inputs you have. It is possible to set up Linuxcnc to use as many as 9 inputs for a 3 axis machine (independent inputs for everything, or as few as 1 while still take advantage of home and +/- hard limits on all axis, and any combination of numbers in between. The fewer inputs that are used the more compromises you will have to live with.
Probably the combination with the most bang for the buck is the one you've chosen with a single input for each axis. You can arrange it using a single switch with a trigger points at each end of travel or two separate switches wired in series. Personally I prefer to configure with hard limits using one side as the home rather than just a home and relying on soft limits. The main advantage to having a separate input for each axis is the ability to home all the axis simultaneously.
9 years 5 months ago #92892 by andypugh
P1 is _NOT_ GND. On the KBIC the potentiometer floats around +100 volts.
I just feel that this needs to be made super-clear. Failure to note this can result in sparks, curiously-scented smokes and empty wallets.
9 years 5 months ago #92893 by fmfchop
I didn't imply that P1 is a ground.
But it does wire to the ground of the "analog" portion of the C41 board....And the 0-10V on the analog portion of the C41 wires to P2.
You can verify it for yourself if you'd like...
cnc4pc.com/Tech_Docs/C41R2%20and%20KB120%20V1.pdf
9 years 5 months ago #92896 by andypugh
fmfchop wrote: I didn't imply that P1 is a ground.
It's not a GND, it's a 0V reference.
(It might well be labelled GND, if it is a true GND, then that's bad.)
I don't want to appear to be coming over too pedantic, but I _very_ nearly had an expensive experience with my own KBIC years ago.
Time to create page: 0.223 seconds
