Forum Header
Step Outputs Inactive
- kylestrong87
- Topic Author
9 years 2 months ago #97964
by kylestrong87
Step Outputs Inactive was created by kylestrong87
I am new to LinuxCNC and the forums. I have done a search but haven't found a similar problem or solution to my issue. I have been trouble shooting the outputs for a couple days now with now luck. At first I was getting zero output or input. After a fewer tests I ended up changing my LPT protocol in the BIOS from "PS/2" to "EPP". At this point I instantly got my limit switches and "DIR" outputs running correctly. But I am still having no "STEP" outputs coming from LinuxCNC. I suspect it is something I am missing in the set up of StepConf or LinuxCNC itself. I do not believe it is a driver issue because when i use the LPT test app that comes with LinuxCNC I can produce 5VDC on the "STEP" pins on the breakout board. I am using pins 2,4,6,8 for "STEP" and pins 3,5,7,9 for "DIR".
System Info:
LinuxCNC 2.7 (+plus linux from livecd)
CNC4PC C10 Breakout Board
4 Gecko G201
4 Stepper (3 Axis)
System Info:
4 Gecko G201
4 Stepper (3 Axis)
- Thank you received: 1480
9 years 2 months ago - 9 years 2 months ago #97973
Replied by Todd Zuercher on topic Step Outputs Inactive
Could you share your ini and hal files for your config? So we can check them for obvious errors.
PS: (This is totally unrelated to your step generation problem.)
I suspect that you are setting up a slaved gantry type machine (hence the 4 steppers for a 3 axis machine). If that is the case. It might be wise for you to run the Development version of Linuxcnc. (At least until version 2.8 is released.) It contains support for assigning more than one motor to an axis, and homing and squaring them in the homing routine.
But you need to be aware that 2.8-Pre is currently the "develoment branch" and updates need to be made with cation, as changes in the code can introduce bugs or break configs. That said, many people use it safely for running real machinery.
Last edit: 9 years 2 months ago by Todd Zuercher.
- kylestrong87
- Topic Author
9 years 2 months ago #97974
by kylestrong87
Replied by kylestrong87 on topic Step Outputs Inactive
Thank you for the advice. I will definitely look into 2.8. Attached you will find all .hal and .ini files that were in my config folder. Thank you for the help. I knew I was going to run into things like this, just not sure how to address them since my understanding of how LinuxCNC works is minimal so far.
9 years 2 months ago #98207
Replied by andypugh on topic Step Outputs Inactive
You have set the step length to 500nS (or, at least, Stepgen has done that for you).
How are you determining that the step pulses are not working? You won't be able to see a 500nS pulse with a multimeter.
- kylestrong87
- Topic Author
9 years 1 month ago #98467
by kylestrong87
So any suggestions on how to log the data being transmitted if any at all on the Step Pins? I need to find out where I'm losing the data. It's either My LinuxCNC Setup (Which I suspect), the C10, or the Gecko drives.
I have not had any luck finding a Parallel port logger for linux.
I have used the parport tester that came with linuxcnc and those pins do transmit 5vdc which I can read on the c10 board. Also when I test those pins my motors do try to step manually. This is why I suspect LinuxCNC because if it was sending the signal or sending it properly then I would at least hear the motors try to move. Just to confirm my direction pins are working properly I can see them changing and holding voltage when the program changing direction.
9 years 1 month ago #98522
Your step length seems rather short (500nS).
Try 5000nS and see if things work better.
You might also want to invert the step pins.
Both of these are simple edits to the HAL if you prefer not to run stepconf again.
the "reset time" sets the step length in nS and the pins can be inverted with a line like you already have for pin 7
setp parport.0.pin-07-out-invert 1
Time to create page: 0.119 seconds
