PCB milling with laser - power off when Z is up
13 years 2 weeks ago #39862 by yello
I did some PCB milling were I converted the Gerber data to PCB milling insulation data to remove the copper and leave the tracks. That works well (if the laminate is flat).
Now I like to try photosensitive laminate and expose the same insulation data with laser. The advantage is that I am not so Z-axis sensitive (PCB laminate is often not totally flat).
But when I go from one track to the next track the CNC tool will move up, and move the next track. When I do that with the laser the laser power will stay ON and the travel track will be exposed.
Is there a way to switch the laser power OFF when the Z-Axis moves up?
Or is there any way to incorporate that into software/hardware?
13 years 2 weeks ago #39863 by cncbasher
how are you switching the laser on and off ?
use the same as if it was a spindle i.e M3 and M5 to turn off
so you may need to adjust your gcode or postprocessor to add the approprate codes
it might be helpful to add a delay to allow the laser to turn off and on , i have had to do that on some lasers that had mechanical shutters , so it may work in your case
also diode lasers are extremley broad in beam size and extrainious light patterens , so you may need to sheild the laser and just have for argument a 0.5mm hole for the beam
13 years 2 weeks ago #39868 by andypugh
yello wrote: Is there a way to switch the laser power OFF when the Z-Axis moves up?
Of course! There is always a way with LinuxCNC.
The ddt function can be used to detect if the spindle is going up or down: www.linuxcnc.org/docs/html/man/man9/ddt.9.html
Then the abs function can be used to create pins for "is-positive" (going up) or "is-negative" (going down) www.linuxcnc.org/docs/html/man/man9/abs.9.html
Then you can use a flip-flop connected to the is-positive and is-negative to latch the state www.linuxcnc.org/docs/html/man/man9/flipflop.9.html
13 years 2 weeks ago - 13 years 2 weeks ago #39936 by yello
cncbasher wrote: how are you switching the laser on and off ?
I use only XYZ data, the spindle on/off and speed I do manually.
I have of course extra pins in the parallel cable. How do I get there? Get the wires out, or?
And what function I should use exactly? I saw there are some digital pins, what do they do? Go high (5V) when ON? Is so then I could simply put a relays or FET there. (Relays is maybe not so good because of the buzz)
cncbasher wrote: also diode lasers are extremley broad in beam size and extrainious light patterens , so you may need to sheild the laser and just have for argument a 0.5mm hole for the beam
My BluRay 100mW LD has a very simple 1 lens optic. I get a small focus point, maybe 0.5mm or less (hard to see). I could work with tube and a hole at the end. So far I didn't do any exposure tests. A better, or more suitable optic would be another option. So in case you have any link or advice.......
Last edit: 13 years 2 weeks ago by yello.
13 years 2 weeks ago - 13 years 2 weeks ago #39941 by cncbasher
add in stepconf a spindle output , so select a spare pin as Spindle CW , this will give you an output that you can drive a relay and will give you on/off with M3 / M5
also if you add spindle pwm to a pin that would give you an output to vary the power level of the diode , using the spindle value as a level , if you can interface the pwm output to your laser driver
Last edit: 13 years 2 weeks ago by cncbasher.
13 years 2 weeks ago #39943 by andypugh
There is a certain advantage to the approach of using HAL to detect "virtual" Z-axis motion, the existing milling G-code can be used.
(though possibly not, as it is likely to create a "negative")
Time to create page: 0.313 seconds
