Inverting the Direction of a joint in Tandem Axis has no effect
5 years 5 months ago - 5 years 5 months ago #208581 by MartyJ
Hello all,
I am setting up a XYYZ gantry machine. 5i25/single 7i76 setup driving Leadshine closed-loop stepper drivers.
I want to invert the direction of the tandem joint, in my case, that's stepgen 3, using:
setp hm2_5i25.0.stepgen.03.direction.invert_output true
  • Because it's a closed-loop driver system, switching A+/A- wires will not work to invert the direction of the motor.
  • The stepscale is a positive value for both joints in this tandem axis.
  • There is no combination of stepscale sign or inverting stepgens 01 or 03 which result in stepgen 03 inverting its drection, even though I verify that the stepgen.03.direction.invert_output parameter is successfully registered as "true".
Any other ideas? Ini/HAL attached, thanks!
image missing https://i.imgur.com/kh4OnL4.png
Last edit: 5 years 5 months ago by MartyJ.
5 years 5 months ago #208587 by tommylight
The direction can be inverted by simply putting a - in front of the SCALE in the ini file, or removing it if there is already there.
The following user(s) said Thank You: MartyJ
5 years 5 months ago - 5 years 5 months ago #208599 by MartyJ
Thanks! So I tried that, that's what "POS" and "NEG" mean in the STEPSCALE fields in the chart in my first post.
For my primary joint on stepgen 01, adding a - in front of the stepscale value reverses the direction of the motor. For the secondary stepgen, it does not.
5 years 5 months ago #208600 by PCW
Since stepgen 3 never changes direction, I would suspect a hardware problem
5 years 5 months ago #208601 by MartyJ
Huh. I'll try hooking it up to stepgen 4 and see what happens, thanks for the idea.
5 years 5 months ago #208603 by PCW
Might be drive wiring also
You can test the direction inversion with a voltmeter or just a
LED and halcmd
halcmd setp hm2_5i25.0.stepgen.03.direction.invert_output true
halcmd setp hm2_5i25.0.stepgen.03.direction.invert_output false
Should toggle the output polarities of the direction 3 outputs
Time to create page: 0.212 seconds
