Hi, thank you for your reply. I have read your documents on your build, very impressive, thanks for the detailed sharing and documenting.I documented my e-stop setup using an external safety relay in the post linked below:
forum.linuxcnc.org/12-milling/50559-opti...rsion?start=0#284533
Maybe it will help you get your setup up and running.
Hi, thank you for your quick reply. I have been looking at these halshow/scope bits but could not get it to click.if estop-latch.N.ok-out goes false, one of these must have changed:
estop-latch.N.ok-in goes false
estop-latch.N.fault-in goes true
So I would watch these in halshow or halscope to see whats happening.
I also don't understand why you have two estop latches. It seems that one
should be sufficient (adding some logic if you need to add fault inputs or OK inputs)
Yes please, i tried it myself but i guess that is not possible. Thanks!Should we delete the two duplicate replies above without the quoted text?
