Mesa 5i20/7i29 trying to get more out of servos
10 years 7 months ago #71204 by greenbuggy
Machine is a Lagun FTV-3 that I've retrofitted with an intel Atom mobo, Mesa 5i20 FPGA, 2x 7i29 servo drives. Upgraded the servo motors from original Electrocraft 90V units to Baldor 150 VDC motors at 2:1 reduction from a newer Lagunamatic mill that was parted out.
Right now in lagun.ini X/Y/Z axis are all set as following:
Output_scale = 100
Max_Output = 95
Tonight I upgraded my power supply situation so instead of putting out 90 VDC (as I had limited the old power supply to the max voltage of the old servos) I'm putting out 150VDC unregulated using a 2.8 kVA transformer, feeding thru rectifiers into 2 banks of 2 ea 56000 uF 80 VDC capacitors (4 capacitors total wired series-parallel).
I want to get faster acceleration out of these motors....Right now I'm lucky to get 200 and I know that these motors, with this reduction on a Lagunamatic 310 is capable of 350 IPM.
I can't help but feel like the torque they exhibit when I resist them at the ballscrew shafts just seems weak. I haven't put a torque wrench on the servo shaft or ballscrew shaft to verify actual in/lbs but will probably do so tomorrow.
I have put a voltmeter on my capacitor bank to verify that with the servo fully resisting me I get ~12 VDC drop. So from 150 VDC resting voltage I get 138 VDC with a single servo fighting my wrench. I have not yet put an amp clamp on the motor lead to see how much its actually drawing. I know brushes are good, and motors do not smell or appear to have ever overheated or cooked.
A couple of thoughts I had - I know the Mesa 7i29's have a current limit setting, but the manual says that the default setting from the factory is the higher one (22.5A) and I have to pull the heatsink to change this setting. I've never had the heatsinks off so unless they came preset to the lower one I doubt this would be the case.
I know I can bump my max_output to 100 from where its currently sitting at 95 but assuming this scales linearly, I don't think I'm going to nearly double my IPM or torque from a 5% increase in that value
I could bump my voltage up higher to where the motors are seeing 150 VDC while being resisted, but I suspect my problem is current and not voltage-related. As I understand it current is where my torque comes from, not voltage.
I could bump PID values to a higher P value but I think I'm pretty well optimized there as far as keeping overrun and oscillation at bay. For the Y axis I was resisting, current values are P 12000 I 6 D 15 - do these seem reasonable?
Thankful for any other help or ideas to test out what I can/should be doing to improve acceleration and torque out of my setup.
10 years 7 months ago #71218 by Todd Zuercher
As far as servo tuning goes, what are your FF1/FF2 settings, these may help with your accleleration, but not your lack of stiffness. If it isn't stiff enough then you probably need more P (if you power supply isn't running out of oomph.)
10 years 7 months ago - 10 years 7 months ago #71228 by PCW
A couple of things:
Maximum velocity is determined by voltage, not current (acceleration is limited by current but you
are talking about IPM which is is velocity)
You need to bound the maximum PWM setting with the
7I29 so the max output = 95 is correct DO NOT change this
(this is needed for the high side gate drivers to get power)
Bare Hbridge drives (like the 7I29) require FF1 to compensate for the motors backEMF
Have you calculated the maximum speed based on the ballscrew pitch. belt reduction and motorV/KRPM?
maybe you simple cant get to 350 IPM with your current setup
Last edit: 10 years 7 months ago by PCW.
10 years 7 months ago #71367 by greenbuggy
PCW wrote: Have you calculated the maximum speed based on the ballscrew pitch. belt reduction and motorV/KRPM?
Double check my math here:
I originally put reduction is 1:2, double checked that wasn't quite right - on X axis I've got 14:26 reduction so 7:13 simplified
I have 5 TPI ballscrews
Max RPM on my motors is listed at 2500
So at 2500 RPM x (7:13) = 1346 (rounded off) RPM at the ballscrew
1346/5 = 269.2 max IPM possible. So 350 IPM is not possible, but I should be able to do better than 200 IPM rapid
I'm going to try upping the FF1 and continuing to try and improve PID tune.
10 years 7 months ago #71370 by PCW
Remember that you had only 138V under load *0.95 PWM max so RPM is about 2185 max
This works out to about 235 IPM but you need some voltage margin for the motors, at least 20%
so 200 IPM is about the expected maximum speed
10 years 7 months ago #71372 by greenbuggy
Some extra testing:
I put a digital torque wrench on both X and Y axis screws to see how much torque I had.
Got ~10.3 ft/lbs on X, ~10.5 on Y.
For the sake of consistent numbers, multiplying by 12 gets me 123.6 in/lb on X, 126 on Y
Both motors are rated at 28 in/lb stall torque
Since I'm gearing down with the toothed belts I'm under the impression torque should be (26/14) * 28 in/lb which gets me 52 (rounded) in/lb
So now I'm confused. I still think my torque should be a bit higher (for comparison sake, Servo sells a knee mill power feed for X & Y that peaks at around 140 or 150 in/lb of torque, depending on model). But it would seem that in real world measurements I'm getting significantly more torque than these motors are rated for, so maybe I need to upgrade motors to higher torque models in order to get better acceleration and rapid speeds out of this mill. Thoughts?
Moderators: PCW, jmelson
Time to create page: 0.237 seconds
