SSerial on 7i47 ... does a known working configuration exist?
9 years 8 months ago #87813 by jCandlish
I have successfully flashed my combined encoder+sserial bitfile to my 7i80 card, but the attached sserial devices are not recognized.
Does any working configuration of SSerial exist for the 7i47???
latheoperator@125cnc:/lib/firmware/hm2/7i80hd16$ mesaflash --verbose --device 7i80 --addr 10.100.10.100 --sserial SSLBP port 0: SSLBP Version: 1.43 SSLBP Channels: 2 SSLBP Baud Rate: 2500000 interface type: 12 interface width: 8 SSLBP Channel Start: 112 SSLBP Channel Stride: 50 SSLBP Processor Type: d8 SSLBP Clock: 100 MHz latheoperator@125cnc:/lib/firmware/hm2/7i80hd16$
latheoperator@125cnc:/lib/firmware/hm2/7i80hd16$ mesaflash --verbose --device 7i80 --addr 10.100.10.100 --readhmid Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I80 FPGA Size: 16 KGates FPGA Pins: 256 Number of IO Ports: 3 Width of one I/O port: 24 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCount There are 6 of MuxedQCount in configuration Version: 3 Registers: 5 BaseAddress: 3500 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: MuxedQCountSel There are 1 of MuxedQCountSel in configuration Version: 0 Registers: 0 BaseAddress: 0000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: PWM There are 6 of PWM in configuration Version: 0 Registers: 5 BaseAddress: 4000 ClockFrequency: 200.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5A00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 3 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: QCount There are 12 of QCount in configuration Version: 2 Registers: 5 BaseAddress: 3000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for P1 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort PWM 0 /Enable (Out) 3 1 IOPort MuxedQCount 0 MuxQ-A (In) 5 2 IOPort MuxedQCount 0 MuxQ-B (In) 7 3 IOPort MuxedQCount 0 MuxQ-IDX (In) 9 4 IOPort MuxedQCount 1 MuxQ-A (In) 11 5 IOPort MuxedQCount 1 MuxQ-B (In) 13 6 IOPort MuxedQCount 1 MuxQ-IDX (In) 15 7 IOPort MuxedQCount 2 MuxQ-A (In) 17 8 IOPort MuxedQCount 2 MuxQ-B (In) 19 9 IOPort MuxedQCount 2 MuxQ-IDX (In) 21 10 IOPort MuxedQCountSel 0 MuxSel0 (Out) 23 11 IOPort PWM 0 PWM (Out) 25 12 IOPort PWM 0 Dir (Out) 27 13 IOPort PWM 1 PWM (Out) 29 14 IOPort PWM 1 Dir (Out) 31 15 IOPort PWM 2 PWM (Out) 33 16 IOPort PWM 2 Dir (Out) 35 17 IOPort PWM 3 PWM (Out) 37 18 IOPort PWM 3 Dir (Out) 39 19 IOPort PWM 4 PWM (Out) 41 20 IOPort PWM 4 Dir (Out) 43 21 IOPort PWM 5 PWM (Out) 45 22 IOPort PWM 5 Dir (Out) 47 23 IOPort PWM 0 /Enable (Out) IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 24 IOPort None 3 25 IOPort None 5 26 IOPort None 7 27 IOPort None 9 28 IOPort SSerial 0 RXData1 (In) 11 29 IOPort QCount 1 Quad-A (In) 13 30 IOPort SSerial 0 RXData2 (In) 15 31 IOPort QCount 1 Quad-B (In) 17 32 IOPort None 19 33 IOPort QCount 1 Quad-IDX (In) 21 34 IOPort QCount 0 Quad-A (In) 23 35 IOPort QCount 2 Quad-A (In) 25 36 IOPort QCount 0 Quad-B (In) 27 37 IOPort QCount 2 Quad-B (In) 29 38 IOPort QCount 0 Quad-IDX (In) 31 39 IOPort QCount 2 Quad-IDX (In) 33 40 IOPort None 35 41 IOPort None 37 42 IOPort None 39 43 IOPort None 41 44 IOPort SSerial 0 TXData1 (Out) 43 45 IOPort SSerial 0 TXData2 (Out) 45 46 IOPort None 47 47 IOPort None IO Connections for P3 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 48 IOPort None 3 49 IOPort None 5 50 IOPort None 7 51 IOPort None 9 52 IOPort None 11 53 IOPort None 13 54 IOPort None 15 55 IOPort None 17 56 IOPort None 19 57 IOPort None 21 58 IOPort None 23 59 IOPort None 25 60 IOPort None 27 61 IOPort None 29 62 IOPort None 31 63 IOPort None 33 64 IOPort None 35 65 IOPort None 37 66 IOPort None 39 67 IOPort None 41 68 IOPort None 43 69 IOPort None 45 70 IOPort None 47 71 IOPort None latheoperator@125cnc:/lib/firmware/hm2/7i80hd16$
9 years 8 months ago - 9 years 8 months ago #87816 by PCW
sure, some have been used for many years
PIN_SSSVST2_2_4_7I47_72.vhd is an example pinout file
A pinout/ RS-422 polarity error is a likely cause of sserial not working
(since the 7I47 will have a somewhat weird RS-422 pinout)
I dug this out of an old email, might be helpful:
7I47 TXN- --> CAT5 ORANGE/WHITE
7I47 TXN+ --> CAT5 ORANGE
7I47 RXN- --> CAT5 GREEN/WHITE
7I47 RXN+ --> CAT5 GREEN
7I47 GND --> CAT5 BLUE BLUE/WHITE
7I47 +5 --> CAT5 BROWN BROWN/WHITE
Last edit: 9 years 8 months ago by PCW.
9 years 8 months ago #87822 by jCandlish
OK, reflashed according to your muxed encoder recommendation, and rewired as above.
Still no SSerial device is detected.
IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 24 IOPort None 3 25 IOPort None 5 26 IOPort None 7 27 IOPort None 9 28 IOPort SSerial 0 RXData1 (In) 11 29 IOPort MuxedQCount 4 MuxQ-A (In) 13 30 IOPort SSerial 0 RXData2 (In) 15 31 IOPort MuxedQCount 4 MuxQ-B (In) 17 32 IOPort None 19 33 IOPort MuxedQCount 4 MuxQ-IDX (In) 21 34 IOPort MuxedQCount 3 MuxQ-A (In) 23 35 IOPort MuxedQCount 5 MuxQ-A (In) 25 36 IOPort MuxedQCount 3 MuxQ-B (In) 27 37 IOPort MuxedQCount 5 MuxQ-B (In) 29 38 IOPort MuxedQCount 3 MuxQ-IDX (In) 31 39 IOPort MuxedQCount 5 MuxQ-IDX (In) 33 40 IOPort None 35 41 IOPort None 37 42 IOPort None 39 43 IOPort None 41 44 IOPort SSerial 0 TXData1 (Out) 43 45 IOPort SSerial 0 TXData2 (Out) 45 46 IOPort None 47 47 IOPort None
on P4 of the 7i47 I have:
pin cat5 color function 1 green RX0 2 green/white /RX0 6 br+br/white +5 19 orange TX0 20 orange/white /TX0 21 bl+bl/white GND
At this time I have only the 7i84 attached.
Ideas???
9 years 8 months ago #87823 by PCW
Does the 7I84 have field power applied? (do you get a red light when not running?)
9 years 8 months ago #87824 by jCandlish
Yes
+12 volts at pin 5 VIN field power
0 volts at 8 pin 8 GND field power
Jumper W1 is in positioned to the right for separate VIN.
CR2 is illuminated yellow
CR6 is illuminated red
CR8 is illuminated yellow
I have also tried connecting to the 7i73. None of its LEDs illuminate.
9 years 8 months ago #87825 by PCW
if none of the 7I73 LEDS illuminate, that suggest an electrical problem
(you should always get the RED fault LED if no communuications are occuring)
Moderators: PCW, jmelson
Time to create page: 0.170 seconds
