- Thank you received: 10
Part of my reasoning going with an eathernet based card is the PC is not teathered to the router location.tommylight wrote: I personally never use a 5V power supply, i just cut a USB cable and wire to the controlling computer. That has also the benefit of being at the same potential, so grounding is taken care of.
I found in the 7i96e manual the host supply max current is 250mA no external load. The external loads are expansion cards correct? Does the 250mA also included the current soucing all the step and direction outputs to the drivers cards?tommylight wrote: Depends on what can you find:
5V can be used from computer USB, requires cutting and wiring and VERY careful not to reverse the polarity
5V can be used from second hand USB mobile phone chargers, use original 5V ones for Samsung or Iphone, again polarity
16 - 20V can be used from second hand Laptop chargers, again original ones, very nice and very stable
5V and 12V can be used from an old computer power supply, same power supply provides both and some more
Or get new ones, a 5V and a 24V should do nicely
