Hello
I have 2 5i20 + 5 x 7i37COM + 7i48 Mesacards in my Mill and works fine.
i want to add a 6i25 +7i74 for SSERIAL Encoders, but this ends in a crash
Verbose mode on
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0-pre1-4700-gedd61b82a
Machine configuration directory is '/home/chiron/linuxcnc/configs/chironFZ16'
Machine configuration file is 'chiron.ini'
INIFILE=/home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
VERSION=1.1
PARAMETER_FILE=hm2-servo.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
Found file(REL): ./hm2-servo.hal
Note: Using POSIX realtime
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort
hm2/hm2_5i25.0: IO Pin 008 (P3-05): IOPort
hm2/hm2_5i25.0: IO Pin 009 (P3-06): IOPort
hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): Encoder #1, pin Index (Input)
hm2/hm2_5i25.0: IO Pin 032 (P2-12): Encoder #1, pin B (Input)
hm2/hm2_5i25.0: IO Pin 033 (P2-13): Encoder #1, pin A (Input)
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
hm2_pci: discovered 5i20 at 0000:06:00.0
hm2/hm2_5i20.0: 72 I/O Pins used:
hm2/hm2_5i20.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_5i20.0: IO Pin 001 (P2-03): IOPort
hm2/hm2_5i20.0: IO Pin 002 (P2-05): IOPort
hm2/hm2_5i20.0: IO Pin 003 (P2-07): IOPort
hm2/hm2_5i20.0: IO Pin 004 (P2-09): IOPort
hm2/hm2_5i20.0: IO Pin 005 (P2-11): IOPort
hm2/hm2_5i20.0: IO Pin 006 (P2-13): IOPort
hm2/hm2_5i20.0: IO Pin 007 (P2-15): IOPort
hm2/hm2_5i20.0: IO Pin 008 (P2-17): IOPort
hm2/hm2_5i20.0: IO Pin 009 (P2-19): IOPort
hm2/hm2_5i20.0: IO Pin 010 (P2-21): IOPort
hm2/hm2_5i20.0: IO Pin 011 (P2-23): IOPort
hm2/hm2_5i20.0: IO Pin 012 (P2-25): IOPort
hm2/hm2_5i20.0: IO Pin 013 (P2-27): IOPort
hm2/hm2_5i20.0: IO Pin 014 (P2-29): IOPort
hm2/hm2_5i20.0: IO Pin 015 (P2-31): IOPort
hm2/hm2_5i20.0: IO Pin 016 (P2-33): IOPort
hm2/hm2_5i20.0: IO Pin 017 (P2-35): IOPort
hm2/hm2_5i20.0: IO Pin 018 (P2-37): IOPort
hm2/hm2_5i20.0: IO Pin 019 (P2-39): IOPort
hm2/hm2_5i20.0: IO Pin 020 (P2-41): IOPort
hm2/hm2_5i20.0: IO Pin 021 (P2-43): IOPort
hm2/hm2_5i20.0: IO Pin 022 (P2-45): IOPort
hm2/hm2_5i20.0: IO Pin 023 (P2-47): IOPort
hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
hm2/hm2_5i20.0: IO Pin 034 (P3-21): IOPort
hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
hm2/hm2_5i20.0: IO Pin 048 (P4-01): IOPort
hm2/hm2_5i20.0: IO Pin 049 (P4-03): IOPort
hm2/hm2_5i20.0: IO Pin 050 (P4-05): IOPort
hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
hm2/hm2_5i20.0: registered
hm2_5i20.0: initialized AnyIO board at 0000:06:00.0
hm2_pci: discovered 5i20 at 0000:06:01.0
hm2: no firmware specified in config modparam! the board had better have firmware configured already, or this won't work
hm2/hm2_5i20.1: invalid cookie, got 0x00000100, expected 0x55AACAFE
hm2/hm2_5i20.1: FPGA failed to initialize, or unexpected firmware?
hm2_5i20.1: board fails HM2 registration
RTAPI_PCI: Unmapped 65536 bytes at 0x7f95a60b6000
Driver probe function failed!
hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
hm2/hm2_5i25.0: unregistered
RTAPI_PCI: Unmapped 65536 bytes at 0x7f95a625c000
hm2_5i20.0: dropping AnyIO board at 0000:06:00.0
hm2/hm2_5i20.0: unregistered
RTAPI_PCI: Unmapped 65536 bytes at 0x7f95a60c6000
hm2_pci: error registering PCI driver
hm2_pci: rtapi_app_main: Operation not permitted (-1)
./hm2-servo.hal:40: waitpid failed /usr/bin/rtapi_app hm2_pci
./hm2-servo.hal:40: /usr/bin/rtapi_app exited without becoming ready
./hm2-servo.hal:40: insmod for hm2_pci failed, returned -1
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/chiron/linuxcnc_debug.txt
and
Debug Mode
Debug mode on
+ getopts dvlhkr opt
+ shift 1
+ case "" in
+ '[' -z ']'
+ tty -s
+ trap ErrorCheck EXIT
+ '[' '!' -z chiron.ini ']'
+ case "$1" in
++ pwd
+ INIFILE=/home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+ shift
+ EXTRA_ARGS=
+ RUN_IN_PLACE=no
+ echo RUN_IN_PLACE=no
+ LINUXCNCVERSION=2.8.0-pre1-4700-gedd61b82a
+ export LINUXCNCVERSION
+ INIVAR=inivar
+ HALCMD='halcmd '
+ PICKCONFIG='/usr/bin/wish8.6 /usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl'
+ LINUXCNC_EMCSH=/usr/bin/wish8.6
+ echo LINUXCNC_DIR=
+ echo LINUXCNC_BIN_DIR=/usr/bin
+ echo LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
+ echo LINUXCNC_SCRIPT_DIR=
+ echo LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
+ echo LINUXCNC_CONFIG_DIR=
+ echo LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs
+ echo INIVAR=inivar
+ echo HALCMD=halcmd
+ echo LINUXCNC_EMCSH=/usr/bin/wish8.6
+ export LINUXCNC_TCL_DIR
+ export LINUXCNC_EMCSH
+ export LINUXCNC_HELP_DIR
+ export LINUXCNC_LANG_DIR
+ export REALTIME
+ export HALCMD
+ export LINUXCNC_NCFILES_DIR
+ '[' -z ']'
+ echo 'LINUXCNC - 2.8.0-pre1-4700-gedd61b82a'
+ '[' '!' -z '' ']'
+ '[' '!' -n /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini ']'
++ handle_includes /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
++ hdr='# handle_includes():'
++ inifile=/home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+++ dirname /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
++ cd /home/chiron/linuxcnc/configs/chironFZ16
++ /bin/grep '^#INCLUDE' /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
++ status=1
++ '[' 1 -ne 0 ']'
++ echo /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
++ return 0
+ INI_NAME=chiron.ini
+ INI_DIR=/home/chiron/linuxcnc/configs/chironFZ16
+ CONFIG_DIR=/home/chiron/linuxcnc/configs/chironFZ16
+ export CONFIG_DIR
+ export PATH=/home/chiron/linuxcnc/configs/chironFZ16/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
+ PATH=/home/chiron/linuxcnc/configs/chironFZ16/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
+ '[' -z ']'
+ echo 'Machine configuration directory is '\''/home/chiron/linuxcnc/configs/chironFZ16'\'''
+ echo 'Machine configuration file is '\''chiron.ini'\'''
+ '[' '!' -f /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini ']'
+ echo INIFILE=/home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+ retval=
+ GetFromIni VERSION EMC
+ name=VERSION
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var VERSION -sec EMC
+ retval=1.1
+ '[' '!' -n VERSION ']'
+ echo VERSION=1.1
+ '[' 1.1 '!=' 1.1 ']'
+ /usr/bin/tclsh8.6 /usr/share/linuxcnc/hallib/check_config.tcl /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+ exitval=0
+ case "$exitval" in
+ GetFromIni PARAMETER_FILE RS274NGC
+ name=PARAMETER_FILE
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var PARAMETER_FILE -sec RS274NGC
+ retval=hm2-servo.var
+ '[' '!' -n PARAMETER_FILE ']'
+ echo PARAMETER_FILE=hm2-servo.var
+ RS274NGC_PARAMFILE=hm2-servo.var
+ GetFromIniEx MOT MOT EMCMOT EMCMOT motmod
+ original_var='[MOT]MOT'
+ '[' 5 -ge 2 ']'
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var MOT -sec MOT
+ retval=
+ shift 2
+ '[' 3 -ge 2 ']'
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var EMCMOT -sec EMCMOT
+ retval=motmod
+ return
+ EMCMOT=motmod.so
+ GetFromIniEx IO IO EMCIO EMCIO io
+ original_var='[IO]IO'
+ '[' 5 -ge 2 ']'
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var IO -sec IO
+ retval=
+ shift 2
+ '[' 3 -ge 2 ']'
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var EMCIO -sec EMCIO
+ retval=io
+ return
+ EMCIO=io
+ GetFromIni TASK TASK
+ name=TASK
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var TASK -sec TASK
+ retval=milltask
+ '[' '!' -n TASK ']'
+ echo TASK=milltask
+ EMCTASK=milltask
+ '[' milltask = emctask ']'
+ EMCSERVER=linuxcncsvr
+ GetFromIniQuiet HALUI HAL
+ name=HALUI
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var HALUI -sec HAL
+ retval=halui
+ '[' '!' -n HALUI ']'
+ echo HALUI=halui
+ HALUI=halui
+ GetFromIni DISPLAY DISPLAY
+ name=DISPLAY
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var DISPLAY -sec DISPLAY
+ retval=gmoccapy
+ '[' '!' -n DISPLAY ']'
+ echo DISPLAY=gmoccapy
++ set -- gmoccapy
++ echo gmoccapy
+ EMCDISPLAY=gmoccapy
++ set -- gmoccapy
++ shift
++ echo
+ EMCDISPLAYARGS=
+ case $EMCDISPLAY in
+ GetFromIniEx NML_FILE LINUXCNC NML_FILE EMC /usr/share/linuxcnc/linuxcnc.nml
+ original_var='[LINUXCNC]NML_FILE'
+ '[' 5 -ge 2 ']'
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var NML_FILE -sec LINUXCNC
+ retval=
+ shift 2
+ '[' 3 -ge 2 ']'
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var NML_FILE -sec EMC
+ retval=
+ shift 2
+ '[' 1 -ge 2 ']'
+ '[' 1 -eq 0 ']'
+ retval=/usr/share/linuxcnc/linuxcnc.nml
+ NMLFILE=/usr/share/linuxcnc/linuxcnc.nml
+ export NMLFILE
+ GetFromIni COORDINATES TRAJ
+ name=COORDINATES
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var COORDINATES -sec TRAJ
+ retval='X Y Z'
+ '[' '!' -n COORDINATES ']'
+ echo 'COORDINATES=X Y Z'
+ TRAJ_COORDINATES='X Y Z'
+ export TRAJ_COORDINATES
+ GetFromIni KINEMATICS KINS
+ name=KINEMATICS
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var KINEMATICS -sec KINS
+ retval=trivkins
+ '[' '!' -n KINEMATICS ']'
+ echo KINEMATICS=trivkins
+ KINS_KINEMATICS=trivkins
+ export KINS_KINEMATICS
+ KILL_TASK=
+ KILL_TIMEOUT=20
+ LOCKFILE=/tmp/linuxcnc.lock
+ '[' -f /tmp/linuxcnc.lock ']'
+ echo Starting LinuxCNC...
+ trap 'Cleanup ; exit 0' SIGINT SIGTERM
+ touch /tmp/linuxcnc.lock
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var INTRO_GRAPHIC -sec DISPLAY
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var INTRO_TIME -sec DISPLAY
+ imgtime=2
+ '[' 2 = '' ']'
+ '[' linuxcnc.gif '!=' '' ']'
+ '[' -e linuxcnc.gif ']'
+ '[' -e /home/chiron/linuxcnc/configs/chironFZ16/linuxcnc.gif ']'
+ '[' -e /usr/share/linuxcnc/linuxcnc.gif ']'
+ img=/usr/share/linuxcnc/linuxcnc.gif
+ '[' /usr/share/linuxcnc/linuxcnc.gif '!=' '' ']'
+ '[' -x /usr/lib/tcltk/linuxcnc/bin/popimage ']'
+ echo 'Starting LinuxCNC server program: linuxcncsvr'
+ /usr/lib/tcltk/linuxcnc/bin/popimage /usr/share/linuxcnc/linuxcnc.gif 2
+ program_available linuxcncsvr
+ type -path linuxcncsvr
+ export INI_FILE_NAME=/home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+ INI_FILE_NAME=/home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+ linuxcncsvr -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+ echo 'Loading Real Time OS, RTAPI, and HAL_LIB modules'
+ /etc/init.d/realtime start
+ export HAL_RTMOD_DIR=/usr/lib/linuxcnc/modules
+ HAL_RTMOD_DIR=/usr/lib/linuxcnc/modules
+ '[' io '!=' '' ']'
+ echo 'Starting LinuxCNC IO program: io'
+ program_available io
+ type -path io
+ halcmd loadusr -Wn iocontrol io -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
+ '[' -n halui ']'
+ echo 'Starting HAL User Interface program: halui'
+ program_available halui
+ type -path halui
+ halcmd loadusr -Wn halui halui -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var TWOPASS -sec HAL -num 1
+ TWOPASS=
+ '[' -n '' ']'
+ NUM=1
++ inivar -tildeexpand -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var HALFILE -sec HAL -num 1
+ CFGFILE=hm2-servo.hal
+ '[' -n hm2-servo.hal ']'
+ IFS='\ '
+ read CFGFILE CFGFILE_ARGS
+ foundmsg=
+ saveIFS='
+ IFS=:
+ explicit_file_in_hallib=hm2-servo.hal
+ '[' -z hm2-servo.hal ']'
+ '[' hm2-servo.hal '!=' hm2-servo.hal ']'
+ '[' h = / ']'
+ for pathdir in $HALLIB_PATH
+ foundfile=./hm2-servo.hal
+ '[' -r ./hm2-servo.hal ']'
+ foundmsg='Found file(REL): ./hm2-servo.hal'
+ break
+ '[' -d ./hm2-servo.hal ']'
+ IFS='
+ '[' -z 'Found file(REL): ./hm2-servo.hal' ']'
+ echo 'Found file(REL): ./hm2-servo.hal'
+ CFGFILE=./hm2-servo.hal
+ case $CFGFILE in
+ halcmd -i /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -f ./hm2-servo.hal
RTAPI_PCI: Unmapped 65536 bytes at 0x7f0e9edf7000
RTAPI_PCI: Unmapped 65536 bytes at 0x7f0e9ef9d000
RTAPI_PCI: Unmapped 65536 bytes at 0x7f0e9ee07000
+ Cleanup
+ echo 'Shutting down and cleaning up LinuxCNC...'
+ for KILL_TASK in linuxcncpanel iosh linuxcncsh linuxcncrsh linuxcnctop mdi debuglevel gmoccapy gscreen
+ /bin/pidof -x linuxcncpanel
+ /bin/pidof -x iosh
+ /bin/pidof -x linuxcncsh
+ /bin/pidof -x linuxcncrsh
+ /bin/pidof -x linuxcnctop
+ /bin/pidof -x mdi
+ /bin/pidof -x debuglevel
+ /bin/pidof -x gmoccapy
+ /bin/pidof -x gscreen
+ program_available axis-remote
+ type -path axis-remote
+ '[' '!' -z :0.0 ']'
+ axis-remote --ping
+ '[' '' = other ']'
++ inivar -ini /home/chiron/linuxcnc/configs/chironFZ16/chiron.ini -var SHUTDOWN -sec HAL
+ SHUTDOWN=
+ '[' -n '' ']'
+ for KILL_TASK in linuxcncsvr milltask
+ /bin/pidof -x linuxcncsvr
3837
+ KillTaskWithTimeout
+ '[' '!' -n '' ']'
++ /bin/pidof -x linuxcncsvr
+ KILL_PIDS=3837
+ '[' '!' -n 3837 ']'
+ local NPROCS
+ for KILL_PID in $KILL_PIDS
+ /bin/ps -o comm= 3837
+ /bin/grep -q '<defunct>'
+ /bin/kill 3837
+ WAIT=20
+ '[' 20 -gt 1 ']'
++ /bin/ps -o comm= 3837
++ /bin/grep -v '<defunct>'
++ wc -l
+ NPROCS=0
+ '[' 0 -gt 0 ']'
+ WAIT=0
+ '[' 0 -gt 1 ']'
+ '[' 0 -gt 0 ']'
+ '[' 0 -gt 0 ']'
+ KILL_PIDS=
+ KILL_TASK=
+ /bin/pidof -x milltask
+ echo 'Stopping realtime threads'
+ halcmd stop
+ echo 'Unloading hal components'
+ halcmd unload all
hm2: unloading
++ seq 10
+ for i in `seq 10`
++ halcmd list comp
++ wc -w
+ '[' 2 = 1 ']'
+ sleep .2
+ for i in `seq 10`
++ halcmd list comp
++ wc -w
+ '[' 2 = 1 ']'
+ sleep .2
+ for i in `seq 10`
++ halcmd list comp
++ wc -w
+ '[' 1 = 1 ']'
+ break
+ echo 'Removing HAL_LIB, RTAPI, and Real Time OS modules'
+ /etc/init.d/realtime stop
+ echo 'Removing NML shared memory segments'
+ read b x t x x x x x x m x
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ ipcrm -M 1001
+ case $b$t in
+ ipcrm -M 1002
+ case $b$t in
+ ipcrm -M 1003
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ ipcrm -M 1004
+ case $b$t in
+ ipcrm -M 1005
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ case $b$t in
+ rm /tmp/linuxcnc.lock
+ exit -1
+ ErrorCheck
+ result=255
+ echo 'catch {send -async popimage destroy .}; destroy .'
+ /usr/bin/wish8.6
+ '[' 255 -ne 0 ']'
+ tty -s
+ '[' -f /dev/fd/2 ']'
+ echo '(debug information was sent to stderr)'
+ '[' -f /tmp/linuxcnc.print.6ubxST ']'
+ cp /tmp/linuxcnc.print.6ubxST /home/chiron/linuxcnc_print.txt
+ echo 'LinuxCNC terminated with an error. You can find more information in the log:
and
as well as in the output of the shell command '\''dmesg'\'' and in the terminal'
and
as well as in the output of the shell command 'dmesg' and in the terminal
+ rm -f /dev/fd/2 /tmp/linuxcnc.print.6ubxST
+ exit 255
chiron@chiron:~/linuxcnc/configs/chironFZ16$
