8i20 and bldc, upgrading 2.5 to 2.7
7 years 3 months ago - 7 years 3 months ago #140364 by johns00056
My machine has been working great for four years.
I am putting together a ,new, complete replacement spare computer.
The computer and Mesa 5i25 are new. Everything else is unchanged.
I decided to take the opportunity to update from 2.5 ubuntu to 2.7 debian 9 stretch.
I had to change several things in the ini and hal files.
I got it so that linuxcnc will start without error but the servo motors have very little torque and I get a following error immediately when I try to move an axis. If i set the following error to a very large number, the axis will move but is extremely weak.
the 8i20.0.0 current will go up to about 4.3 when I turn the motor pulley by hand.(before it errors)
This is about 30 times higher amperage than what I observe when hooked up to the old computer.
the 8i20 bus-voltage looks good at 166 volts
File Name: 5i25green_...7-23.ini
File Size:13.63 KB
File Name: hm2-servog...7-23.hal
File Size:24.56 KB
Last edit: 7 years 3 months ago by johns00056.
7 years 3 months ago - 7 years 3 months ago #140365 by PCW
There was a change in the way the driver scales the 8I20 current,
I believe between LinuxCNC 2.5 and 2.6 (in any case a fairly long time ago)
The current used to be scaled 0 to +- 1 for full scale current
Now (since 2.6) its scaled in Amps
Last edit: 7 years 3 months ago by PCW.
7 years 3 months ago #140374 by johns00056
PCW, thanks for the help.
By "the driver" do you mean- hostmot2, bldc, pid , or something else?
7 years 3 months ago #140389 by PCW
LinuxCNCs HostMot2 driver
7 years 3 months ago #140757 by andypugh
Is this working now?
7 years 3 months ago #140796 by johns00056
Andy, thanks for the interest. I got it running.
bldc is working fine, I did not change anything in it.
old computer- MAX_OUTPUT = 4.3 -This number is wrong because it is out of range. It should be 1. (I probably won't change it on the old computer)
new computer- MAX_OUTPUT = 15 -(amps) I changed this to 15 and it helped a little bit, but, the motors were still too weak.
OUTPUT_SCALE = 4.7 ---- This number is probably wrong on both the old and new computers but I am not going to change it. I have spent many days on this problem and the machine works well enough as it is.
I re-tuned the servo motors. (torque mode) I ended up multiplying the previous settings for P by 13 and D by 9.5 and adding some FF2.
old computer 2.5 ubuntu
P = 2500
I = 0
D = 15
FF0 = 0
FF1 = 0
FF2 = 0
new computer 2.7 debian 9 stretch
P = 32500
I = 0
D = 143
FF0 = 0
FF1 = 0
FF2 = 2
Now the motors are really strong, stronger than they have ever been.
The remaining problem is - often (about 25% of the time) when a motor is stationary it will start to hum or buzz a little bit. If I put my hand on the motor pulley ,the humming will stop ,and stay stopped
when I take my hand off.
The machine has been like this for five years. I usually push the e-stop button when the machine is not running to stop the buzzing.
I am concerned that the encoders will wear out or that the encoder couplings will loosen on the motor shaft , eventually.
I tried increasing the dead band , but that just increases the apparent backlash in the axis. If I push the motor pulley to one side of this backlash ,sometimes it will just continue to hum at that location.
If I reduce the P by a very large amount ,the humming will stop but,then the motors just seem too weak.
Maybe I am supposed to measure the motor torque to set the P , or something.
Moderators: PCW, jmelson
