6i25 and 7i77 config
10 months 2 weeks ago #340043 by cdamm11
6i25 and 7i77 config was created by cdamm11
Hello LinuxCNC experts!
I am having a hard time setting up my LinuxCNC configuration. I have a 6i25 and 7i77. I have confirmed 5V to the P1 connector and jumper is in right hand. I have 26V on TB2. All others connector i have removed from the 7i77.
I have installed: linuxcnc_2.9.4 amd64.hybrid iso file. My Jitter is good.
I did not buy the 6i25 and 7i77 as a kit. i tried to load the firmware this way;
sudo mesaflash --device 5i25 --write (my directory)/5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
i used the files from mesa website. And it seems to flash without problems.
Than i tried to use pnconf. i setup the encoders XYZ and PWM XYZ and the correct scaling.
When i load the program my pc just reboots. I get no errors. I tried to alot of things from these forums but i cant get any sucess.
Best regards Christian
10 months 2 weeks ago #340045 by tommylight
Replied by tommylight on topic 6i25 and 7i77 config
That is most certainly a PC issue, not Mesa/LinuxCNC issue, so the first thing to try is insert the 6i25 into another PCI-E slot, even the long 16X one will work, and so will 8X and 4X ones.
10 months 2 weeks ago #340046 by cdamm11
Replied by cdamm11 on topic 6i25 and 7i77 config
Hi Tommy!
The PC only has 1 PCIE X16 so that is problematic :(
I can see this in terminal:
mesaflash --device --5i25
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 0 IOPort SSerial 0 TXEn2 (Out)
14 1 IOPort SSerial 0 TXData2 (Out)
2 2 IOPort SSerial 0 RXData2 (In)
15 3 IOPort SSerial 0 TXData1 (Out)
3 4 IOPort SSerial 0 RXData1 (In)
16 5 IOPort SSerial 0 TXData0 (Out)
4 6 IOPort SSerial 0 RXData0 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn5 (Out)
14 18 IOPort SSerial 0 TXData5 (Out)
2 19 IOPort SSerial 0 RXData5 (In)
15 20 IOPort SSerial 0 TXData4 (Out)
3 21 IOPort SSerial 0 RXData4 (In)
16 22 IOPort SSerial 0 TXData3 (Out)
4 23 IOPort SSerial 0 RXData3 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
is there anything else i can test in software / firmware / drivers?
10 months 2 weeks ago #340051 by tommylight
No, not really, you will need another PC at least.
Lets clear something up first, does the PC reboot when turning ON the Mesa cards, or, when running LinuxCNC ?
10 months 2 weeks ago #340053 by cdamm11
the pc only reboots when i try to run my configuration. i can run Sample configurations like "axis". But when i try to run the config i created using pncconf wizard the pc just reboots. i also does this if i try to Open Loop test or test / tune axis.
10 months 2 weeks ago #340054 by tommylight
Moderators: PCW, jmelson
Time to create page: 0.295 seconds
