Mesa 7i96s problem, only one stepgen works
9 months 3 weeks ago #341300 by deckname
Hi, I can´t get my mesa card to work right. (It did before.)
The Problem is that only one axis works at a time.
I,m using LinuxCNC 2.9.6 with QtPlasmaC.
Mesa is connected to DM542T drivers.
I swapped the plugs on the mesa to make sure the hardware works correctly.
Tried different stepgen configurations which made different outputs work, but only one at a time.
Looked at the hal pins, which seem good.
I´m out of ideas and hoping for yours.
9 months 3 weeks ago #341302 by PCW
That sound's more like a wiring or hal file issue than hardware issue with the 7I96S
You might check than the DIR signals for all axis change when jogging each axis in different directions
9 months 2 weeks ago #341324 by deckname
Thank you for the suggestion.
I just measured the DIR signals, they all work fine.
The voltages are between 4.1 and 4.9V which seem a bit low to me, but it should still work with 3.3V.
Any other ideas?
9 months 2 weeks ago #341327 by PCW
Is that 4.1V under load?
4.1V and no load indicates either a damaged output or low 5V supply
What were the low state voltages of the DIR outputs?
9 months 2 weeks ago #341328 by deckname
The voltage changes a bit with load.
The one with the lower voltage has 0.4V at low state, but this one works.
Another one has 4.9V to 0.04V and doesn´t work.
9 months 2 weeks ago #341330 by PCW
"Another one has 4.9V to 0.04V and doesn´t work."
Sounds like a wiring issue as it seems there is  no load on that 7I96S output.
Are the outputs wired differentially? (STEP+and STEP- both used)
The following user(s) said Thank You: deckname
Moderators: PCW, jmelson
Time to create page: 0.138 seconds
