Backlash move midway on linear move since update
10 years 5 months ago #75248 by NHGeorge
Hello new to forum but have been using emc2 for years and just upgraded from 2.7.3 t0 2.7.4 and was contouring a simple rectangle this morning and every time i was moving in y axis on both ends the machine makes a backlash move mid path and leaving a pretty good step. used g61 prior to this upgrade and noticed g61.1 is now exact stop code? tried both and g64 p.001 and slowed feed etc but still get backlash type move. never got this prior to upgrade.
thanks G
10 years 5 months ago #75317 by Todd Zuercher
Could you post your problem g-code as an attachment?
Is your machine setup to use backlash compensation?
Can you measure the offset the move made?
10 years 4 months ago #75426 by NHGeorge
Hi Todd
Thanks I don't think i saved the code but ill take a look later but measured the step and approx .013 and i believe thats also what i have for my backlash set at. The code was pretty simple just my safety line and repeated contour moves at .100 depths that i have used for numerous jobs prior. I did try moving the g61 down and tried g61.1 and g64 p.001 as well as changing feed and was still getting this glitch mid path and remember at some point depending on feed i would get on one end and not the other and at some point in my testing the y would do the same. I feel there is an error in the emc coding dealing with backlash and trajectory planning. I did find in my search for an answer that trajectory planning for this release was a new design vs tweaks to the previous version.
Thanks G
g0 g90 g40 g80 g61
g0 g54 x-.25 y.125 z.1
g01 z-.1 f10.
x6.025 f20.
y-1.825
x-.125
y.125
z-.2 f10.
x6.025 f20.
etc..
10 years 4 months ago #75490 by andypugh
The changes from 2.7.3 to 2.7.4 are listed here:
www.linuxcnc.org/2016/02/08/release-2.7.4/
There were no changes to motion at all.
10 years 4 months ago #75519 by NHGeorge
Hi Andy for some reason I thought I read the traj planner changed. I did some testing and had remembered i had installed Qjoypad to use my game controller as mpg. I unplugged and disabled and test still showing moves mid path, the only thing i can find is if i disable backlash in my ini this stops happening. I attached my files as maybe someone can see something wrong in them.
Thanks G
10 years 4 months ago #75618 by andypugh
is it possible that your actual backlash has increased or decreased?
It could just be the part. LinuxCNC only knows that it has changed direction. It has no way to know that the cutting force has changed direction. So for some parts you will see a move from one side of backash to the other that LinuxCNC has no way to compensate for.
Time to create page: 0.349 seconds
