can i use linuxcnc without it's PID loop?
7 years 5 months ago #133713 by skvallab
can i use linuxcnc as just a step generator ?
without it's PID loop.
7 years 5 months ago #133719 by pl7i92
Yes you can
install latest wheezy stay on 2.7.14
BUT it gives you more benefit if make the pidloop work
its only once you got the things sorted
BESt to use wizard for base config and copy your privete things over
The following user(s) said Thank You: skvallab
7 years 5 months ago #133764 by skvallab
i understand PID can do a great job, but i have a servo drive which does it good enough for my simple application (NO machining involved ).
can you please guide me through how to do it,
i have a pico systems Universal Stepper Controller (Via parallel port)
7 years 5 months ago #133779 by cmorley
Looking at the docs - it seems the Pico card does not have a step generator that supports position mode with an internal PID.
So unless you switch to Mesa or parallel port hardware, you are stuck with PID.
I know with the Mesa card the PID setting is pretty standard to get good results with the standard servo period.
P = 1000 FF = 1
Chris M
7 years 5 months ago #133780 by cmorley
Maybe you are looking for a simple trejectory planner for your non machining application?
simple_tp is a single axis trajectory planner that takes a target position and gives a velocity signal
oprn a teminal and type 'man simple_tp'
7 years 5 months ago #134295 by tommylight
skvallab wrote: can i use linuxcnc as just a step generator ?
Yes.
Linuxcnc has its pid loop just in case you need it for steppers.
Time to create page: 0.261 seconds
