Linuxcnc phantom switch
6 years 5 months ago #169426 by anfänger
Hi folks,
my machine won't power up cause it's telling that xis 2 is at it's limit.
but it isn't. All limit switches are working and free.
the machine has run before.
so i have two questions.
first: is it possible to tell linuxcnc to powrs on the machine with tripped limits?
second: any one an idea whats wrong?
thanks Patrick
6 years 5 months ago #169427 by tommylight
Replied by tommylight on topic Linuxcnc phantom switch
On axis GUI, under the homing button, there is "ignore limits", click on it and enable the machine.
To check the switches, open "machine" > "show hal configuration" chose "show" on the right side and find the input pins on the left side and click on them, then manually toggle the switches and check if the LED's change state.
The following user(s) said Thank You: anfänger
6 years 5 months ago #169431 by anfänger
Replied by anfänger on topic Linuxcnc phantom switch
Thanks, I already checked with halshow they are all good. Actually I also have Hal leds do see all my switches which can trigger e stop. They are all good.
I use probe basic. Which seems to miss this
6 years 5 months ago #169432 by anfänger
I changed Hal to make sure it is a software problem. But it is a hardware one. My limit switch very shortly opens when I power on the machine. The halscope helped to figure it out
Thanks for your help.
6 years 5 months ago #169433 by tommylight
In that case, you might want to talk directly to the developers on IRC
webchat.freenode.net/#linuxcnc
that is for Linuxcnc,
webchat.freenode.net/#hazzy
This is for probe basic. Do not use a password, just type a nicname, preferably the same as in forum.
6 years 5 months ago #169435 by tommylight
anfänger wrote: I changed Hal to make sure it is a software problem. But it is a hardware one. My limit switch very shortly opens when I power on the machine. The halscope helped to figure it out
You are welcomed,
That is an interference issue, so you might want to check the grounding first, change the socket where the machine is plugged, make sure switch wires and input wires do not go in parallel with motor or spindle wires, if you have a spindle some ferrite filters might help especially on the power input wires and on the spindle motor wires.
Time to create page: 0.057 seconds
