wait_complete()
  • RKtech
  • Topic Author
  • New Member
  • New Member
5 years 2 months ago - 5 years 2 months ago #219162 by RKtech
wait_complete() was created by RKtech
I had some issue with the command.wait_complete() command when using with command.mdi().
My system:
- Linuxcnc 2.8.2
- Linux 4.19.0-17-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.194-3 (2021-07-18) x86_64 GNU/Linux
- MESA 7i95
When I installed PSNG ( github.com/linuxcnc-probe-screen/probe-screen-ng ) first it seems to work, but when using larger clearence values, the sensor didn't do the correct movements (at the end the sensor will not move to the end position but stops some way before)
After some experiments I figured out, that the G commands are calculated correctly, but the move wasn't finished. So I observed the wait_complete() command and found, that it allways returns with the return Value "1" after longest 150ms even if the move will take much longer. Also giving a higher timeout will not help, because it didn't timeout anyway..
Currently I have implemented a workaround where the MDI cammands are handled:
def gcode(self, s, data=None):   time_start_RK = time.time() #RK debug   self.command.mode(linuxcnc.MODE_MDI)   self.command.wait_complete()   max_idle_time_RK = time.time()-time_start_RK   print('RK - 0, Workaround in ".../psng/python/base.py"') #RK debug   print("RK - 1: %f ; switch to MDI time" %(max_idle_time_RK)) #RK debug   for l in s.split("\n"):     # Search for G1 followed by a space, otherwise we'll catch G10 too.     if "G1 " in l:     l += " F#<_ini[TOOLSENSOR]RAPID_SPEED>"     self.command.mdi(l)     time_start_RK = time.time() #RK debug     a_RK = self.command.wait_complete()     time_duration_RK = time.time()-time_start_RK     print("RK - 2: %f ; %i ; %s" %(time_duration_RK, a_RK, l)) #RK debug     if self.error_poll() == -1:     return -1   #RK debug   while True:     self.command.mdi(';workaround')     time_start_RK = time.time()     a_RK = self.command.wait_complete(5.0)     time_duration_RK = time.time()-time_start_RK     print("RK - 3: %f ; %i ; loop workaround" %(time_duration_RK, a_RK)) #RK debug     if self.error_poll() == -1:       return -1     if time_duration_RK < max_idle_time_RK:       break     return 0
which give me this result:
... RK - 0, Workaround in ".../psng/python/base.py" RK - 1: 0.041228 ; switch to MDI time RK - 2: 0.010244 ; 1 ; G91 RK - 2: 0.142202 ; 1 ; G1 X15.000000 F#<_ini[TOOLSENSOR]RAPID_SPEED> RK - 2: 0.132048 ; 1 ; G90 RK - 3: 0.142770 ; 1 ; loop workaround RK - 3: 0.112120 ; 1 ; loop workaround RK - 3: 0.142459 ; 1 ; loop workaround RK - 3: 0.010268 ; 1 ; loop workaround ...
what I'm using here is, that if I put something (even a comment like ";workaround") into the MDI the wait_complete() will return within 10ms if it is idle or >100ms if there is some movement.
When wait_complete() need more then 50ms to return I repeat sending this "MDI" command otherwise it is finished.
With this workaround everything works fine (for PSNG) now, but I see a lot of other places (not only in PSNG) where this wait_complete() is used.
Could someone advice me to figure out why this command it is working so odd on my mashine? (I couldn't belive that nobody else had this issue without notyfiing it)
THX
Last edit: 5 years 2 months ago by RKtech.
  • RKtech
  • Topic Author
  • New Member
  • New Member
5 years 2 months ago #219262 by RKtech
Replied by RKtech on topic wait_complete()
Update:
It is (for sure) no linuxcnc issue. I wrote a short python script by myself and here the wait_complete() is working exactly as expected. So I have to dive more deeply into the PSNG code ...
2 years 2 weeks ago #312645 by natester
Replied by natester on topic wait_complete()
Did you ever figure this out? I also found this bug in probe screen v2.8: github.com/verser-git/probe_screen_v2.8/...probe_screen.py#L341
Increasing the timeout makes no difference as wait_complete always returns immediately. I'm also on linuxcnc 2.8.4
2 years 2 weeks ago #312672 by natester
The fix you posted didn't work for me as my wait_complete returns within .1s every time.
Instead, I just polled the interpreter state like so:
    @restore_task_mode     def gcode(self, s, distance=None, data=None):         self.command.mode(linuxcnc.MODE_MDI)         self.timed_wait_complete()         for l in s.split("\n"):             # Search for G1 followed by a space, otherwise we'll catch G10 too.             if "G1 " in l:                 l += " F#<_ini[TOOLSENSOR]RAPID_SPEED>"             time_in = 5             if distance is not None:                 # set a non-default wait limit for wait_complete()                 time_in = 1 + (distance / self.ps_rapid_speed ) * 60             #print("probe_screen time_in=", time_in)             #print("probe_screen:\n", l)             self.command.mdi(l)             self.timed_wait_complete()             if self.error_poll() == -1:                 return -1                      self.stat.poll()             # wait for the interpreter to return to idle state             while self.stat.interp_state != linuxcnc.INTERP_IDLE:                 #print("probe_screen: interp_state=", self.stat.interp_state)                 if self.error_poll() == -1:                     return -1                 self.command.wait_complete()                 self.stat.poll()             self.command.wait_complete()             if self.error_poll() == -1:                 return -1         return 0
11 months 2 days ago - 11 months 2 days ago #339832 by zz912
Replied by zz912 on topic wait_complete()
This line:
github.com/verser-git/probe_screen_v2.8/...probe_screen.py#L338
It doesnt calculate with ramps, so time cant be enough.
I preffer use long time:
timeout = 600 result = self.command.wait_complete(timeout) if result == -1:        print( 'Command timed out: ({} second)'.format(timeout))
forum.linuxcnc.org/38-general-linuxcnc-q...ete-timed-out#296683
Last edit: 11 months 2 days ago by zz912.
11 months 1 day ago #339842 by jcdammeyer
Replied by jcdammeyer on topic wait_complete()
I'm using a slightly older version of the probe screen so the gcode() method is in base.py. I haven't upgraded. I suppose I should.
I'm running axis 2.8.1.
I like the idea of the INI file value [TOOLSENSOR]RAPID_SPEED being used for the movement to/from the start search position. I could then even use F50 for example after tool is up above the work piece. Then when it reaches the other end it goes back to self.ps_rapid_speed from the probe screen parameter which I have set at 10.
However somehow although it works on Thonny the
if "G1 " in l:
is not working. And setting the box on the probe screen to 50 for rapid has the risk of breaking the probe. Actually anything above about 20 has that risk.
Time to create page: 0.159 seconds
