Jitter around 50,000,000 ns
1 year 10 months ago #316069
by martyop
Jitter around 50,000,000 ns was created by martyop
I installed debian 12 and then linuxcnc using the sudo apt install method on a computer that used to run linuxcnc on debian 10.
The jitter numbers are huge, around 50,000,000 ns. On debian 10 they were more like 50,000 ns.
What happened?
What happened?
1 year 10 months ago #316071
Replied by PCW on topic Jitter around 50,000,000 ns
Are you sure you are running a real time kernel?
What does:
uname -a
report?
What does:
uname -a
report?
1 year 10 months ago #316224
by martyop
Replied by martyop on topic Jitter around 50,000,000 ns
Thanks for your reply.
uname -a reports
Linux garage 6.1.0-28-rt-1md64 #1 SNP PREEMPT_RT Debian 6.1.119-1 (2024-11-22) x86_64 GNU/Linux.
The garage computer has an intel atom processor.
uname -a reports
1 year 10 months ago #316225
by martyop
That should be -amd64 not -1md64, my typing error.
1 year 10 months ago - 1 year 10 months ago #316376
by Carlates
Replied by Carlates on topic Jitter around 50,000,000 ns
It is possible that the issue is related to the real-time kernel configuration on Debian 12. Please check if the kernel is compatible with LinuxCNC and make sure the system configuration is optimized for real-time.martyop post=316224 userid=3221
uname -a reports
doodle jump
Last edit: 1 year 10 months ago by Carlates.
1 year 10 months ago #316391
Replied by tommylight on topic Jitter around 50,000,000 ns
Are you using a parallel port or Mesa or Pico control boards?
In a terminal
latency-histogram --nobase --sbinsize 1000 --show
In a terminal
Time to create page: 0.061 seconds
