Raspi 5 SPI setup
1 year 8 months ago #321454 by Wagon56
Raspi 5 SPI setup was created by Wagon56
Hello everyone, im having a hard time setting up SPI on the raspi 5 running a  rpi-5-debian-bookworm image, i thought it would be relevant to ask here. For context, im trying to use some TMC5160T Pro stepper motor drives but to run them in the step/dir config i need to establish a spi connection with the drive to get the step/dir mode active. (i found this information online so i might be wrong)
I have enabled SPI in the /boot/firmware/config.txt and i have also confirmed that /dev/spidev1.0 and 0.0 are active but when i run "gpioinfo | grep spi" i only see the CS pins which (by the logic of chatgpt) is incorrect, i am assuming that i should be seeing the mosi miso and sclk pins in there too.
would love some help setting this up since its just been a headache for someone with as little experience with this stuff as i have.
1 year 8 months ago #321475 by unknown
Replied by unknown on topic Raspi 5 SPI setup
That is fine, as long as there are entries under /dev everything is fine.
1 year 8 months ago #321476 by unknown
And layoff the chatgtp it's not good for your health
1 year 8 months ago #321495 by Wagon56
Replied by Wagon56 on topic Raspi 5 SPI setup
Yeah it doesnt really help with anything lately it just kinda is there as a last resort, i really really started disliking it but i was hoping it would atleast spit out some good info this time, but yeah thanks for the help, will take a look again tomorrow to hopefully get a stepper motor running
1 year 8 months ago #321497 by unknown
If you used the latest RPi image SPI will work. I tested the SPI interface using mesflah to talk to a 7c81 using the /dev/spidev.xx interface and also testing the hm2_spix driver. If either of these failed I would of rectified it before submitting the images to be put up on the downloads page.
The simplest solution was left out via chatgtp, check for the creation of the dev nodes. This has been talked about on the forum.
The following user(s) said Thank You: Wagon56
1 year 8 months ago #321501 by rodw
Replied by rodw on topic Raspi 5 SPI setup
Any time I use ChatGPT or any of his mates, they lie. Although google's gemini did manage to write some Python code for me to connect to an API and look stuff up the other day! I was impressed.
