Plasma Touch Off
15 years 4 months ago #10358 by BigJohnT
Plasma Touch Off was created by BigJohnT
After a recent suggestion I've changed my plasma touch off subroutine. My plasma uses a floating head and a micro switch connected to the probe input.
o<touchoff> sub (#1 pierce height, #2 pierce delay, #3 cut height) F10 G38.2 Z-1.75 (Probe to find the surface) G92 Z-0.070 (Set Z Probe Switch Offset) G1 Z#1 M3 S1 M66 P0 L1 Q5 (Wait for Arc OK from Torch) G4 P#2 (Pause for pierce delay) F25 Z#3 (goto cut height) o<touchoff> endsub M2
An example file using touchoff.ngc
G20 (Units: Inches) G40 (Cancel Cutter Comp) G90 (Absolute Mode) G64 P0.005 (Continuous mode + path tolerance) G92 X0 Y0 o<touchoff> call [0.100] [0] [0.08] (Touchoff and start cutting) F70 G1 X32.1 M5 (Torch Off) G0 Z0.500 X0.000 G92.1 (Cancel offsets and set to zero) G0 Z0 M2
14 years 3 months ago #22167 by tensaiteki
Replied by tensaiteki on topic Re:Plasma Touch Off
I modified John's touch off subroutine.
Now if the torch fails to fire/arc doesn't transfer, it will re-probe and try again instead of just taking off without cutting. If it fails four times in a row, the head will raise up 2 inches and pause the program to allow access to change the torch consumables. Resuming/un-pausing the program will restart the probing and torch firing attempts.
o<touchoff> sub (#1 pierce height, #2 pierce delay, #3 cut height) #<arc-fails> = 0 F40 o100 do G38.2 Z-1.25 (Probe to find the surface) G91 G1 Z0.185 (Raise up to Z0) G90 G92 Z0 (Set Z0) G1 Z#1 (Raise to pierce height) M3 S1 (Fire torch) M66 P0 L1 Q2 (Wait 2 seconds for Arc OK from Torch) o200 if [#5399 EQ -1] (Check to see if torch failed to fire) (MSG, Arc Fail) M5 #<arc-fails> = [#<arc-fails> + 1] o300 if [#<arc-fails> GT 3.0000] (Check if torch has failed 4 times in a row) Z2.0000 (raise torch high enough to change consumables) #<arc-fails> = 0 (reset arc failure counter) M1 (pause) o300 endif o200 endif o100 while [[#5399 EQ -1]] G4 P#2 (Pause for pierce delay) F25 Z#3 (goto cut height) o<touchoff> endsub M2
Usage is the same as in John's first post.
14 years 3 months ago #22191 by BigJohnT
Replied by BigJohnT on topic Re:Plasma Touch Off
Excellent!
I'll give that a try next time I cut a part...
Thanks for sharing
11 years 10 months ago #53721 by jd896
Replied by jd896 on topic Re:Plasma Touch Off
sorry to jump in here but im having a hard time getting this to work now ive added a m66 E0 L0 pin into the mix (used to set pierce time on screen)
the m66 command uses variable #5399 as used here
the hard time im having is to find another variable the will keep this arc monitoring working
thanks
9 years 3 months ago #96682 by travis.gillin
Replied by travis.gillin on topic Plasma Touch Off
I've been using tensaiteki's touchoff routine with retry's for some time with great success. One problem i've been having is if the probe switch sticks on complicated part nests with hundreds of starts, G38.2 will stop the program if the probe is closed when its called. Its difficult to jump back in to a nest like this....
I've added an additional M66 and if statement that checks if the probe is contacted before G38.2 is called. This allows the opportunity to service the issue before G38.2 aborts the program. Important to know, add a hal connection linking the probe input to digital input 1. (Ex "net probe-in <= motion.digital-in-01 <= parport.0.pin-10-in-not")
o<touchoff> sub (#1 pierce height, #2 pierce delay, #3 cut height) #<arc-fails> = 0 F20 o100 do M66 P1 L0 Q0 (Wait 1 second to see if probe is already closed) o400 if [#5399 EQ 1] (MSG, Contact already closed before calling G38.2!) G0 Z2.0000 M0 o400 endif G38.2 Z-1.250 (Probe to find the surface) G91 G1 Z0.020 (Raise up to Z0) G90 G92 Z0 (Set Z0) G1 Z#1 (Raise to pierce height) M3 S1 (Fire torch) M66 P0 L1 Q2 (Wait 2 seconds for Arc OK from Torch) o200 if [#5399 EQ -1] (Check to see if torch failed to fire) M5 #<arc-fails> = [#<arc-fails> + 1] o300 if [#<arc-fails> GT 3.0000] (Check if torch has failed 4 times in a row) Z2.0000 (raise torch high enough to change consumables) (MSG, Change Consumables!) #<arc-fails> = 0 (reset arc failure counter) M0 (pause) o300 endif o200 endif o100 while [[#5399 EQ -1]] G4 P#2 (Pause for pierce delay) F25 Z#3 (goto cut height) o<touchoff> endsub M2
9 years 3 months ago #96704 by rodw
Replied by rodw on topic Plasma Touch Off
Very interesting. I've saved this and will give it a go. Because I am starting off with plasma, I would like to add a way to do a dry run without the touchoff if my torch is disabled in the console so I might see if I can extend this.
