Raspberry Pi5 GPIO setup
1 year 8 months ago #320838 by Wagon56
Hello everyone, ive been trying to set up linuxcnc to work with my Raspberrypi 5 for a week or two now, ive gotten to a point where i can load the hal_pi_gpio driver with no errors showing up, i have a config running in linuxcnc and i can see in halshow that the pins are activating and deactivating, the issue i have is that the pins only activate and deactivate in the software and not physically, i cannot measure any difference on the physical pin itself, i can use gpioset command to set the pins to high or low manually and that works well, but as soon as i try setting it to high/low using halcmd it just doesnt change state, i would greatly appreciate some assistance in setting this up correctly.
The hal file below was given as an example somewhere online, dont remember exactly where i got it but it is as mentioned supposed to work considering that halshow shows the pins and the fact that they should be changing state.
1 year 8 months ago #320840 by scotta
Replied by scotta on topic Raspberry Pi5 GPIO setup
Looking at the source for hal_pi_gpio it's setup for the BCM2835 (RPi 4). The RPi 5 uses the new RP1 southbridge chip for IO.
1 year 8 months ago #320846 by Wagon56
Replied by Wagon56 on topic Raspberry Pi5 GPIO setup
I see, what do i need to do to get it configured for the RP1? Might be a very obvious answer but im a newbie and dont really yet know exactly what im doing.
Do i have to do anything other than redoing the hal file? This issue seems to be a bit deeper than just the hal file (or atleast thats what makes ΔΊ
sense to me)
1 year 8 months ago #320850 by unknown
Replied by unknown on topic Raspberry Pi5 GPIO setup
This may be a starting point
forum.linuxcnc.org/9-installing-linuxcnc...i-5?start=350#320817
But continue reading, as the user did make a few mistakes in the hal file, but these were pointed out in the next post. May not be exactly want you want, being 6 aixs, but it's a starting point.
But yeah it's hal_gpio for the PI5
linuxcnc.org/docs/devel/html/drivers/hal_gpio.html
1 year 8 months ago #320853 by Wagon56
Awesome, thanks, will take a look and see what i can fix, i dont think setting up a config for 6 axis will be a big problem once i actually get the gpio stuff working
1 year 8 months ago #320854 by unknown
The config the user posted was for a 6 axis machine. If that's what you need it should be good to go once you correct the couple of mistakes.
If I may ask, once you have the basic config working, could you attach the files to this thread. As I attempting to have a one stop thread with a heap of info.
forum.linuxcnc.org/9-installing-linuxcnc...the-rpasberry-pi-4-5
Time to create page: 0.364 seconds
