PathPilot and Modbus
10 years 6 months ago #72625 by smgvbest
Has anyone worked on getting a MODBUS devices working with PathPilot, example VFS Spindles? or PLC's for Digital In/Out?
Wondering what would be entailed in doing so?
my best guess is getting full linuxcnc ~2.6.3 compiling. but then can you just copy the modules to /home/operator/tmc/bin and/or lib and use them?
TIA
Sandra
10 years 6 months ago #72636 by cncbasher
Replied by cncbasher on topic PathPilot and Modbus
as far as i can see looking at the sources Modbus is installed , so you should not have any problems
just treat it exactly the same as Linuxcnc .
10 years 6 months ago #72652 by smgvbest
Replied by smgvbest on topic PathPilot and Modbus
Thank you
I did try it and added to my tormach_lathe_sim.hal
loadusr -W mb2hal config=mb2hal.ini
with jsut a default sample config
Immediately got a error. checking the log I say mb2hal not found
went to the sources directory and cp mb2hal ~/tmc/bin
Rebooted, quicker actually
Came up ok this time except excessive logging so tweaked the debug settings in the sample (doesn't actually have anything it's connecting to at this point)
Loaded HAL Components: ID Type Name PID State 30 User halcmd2687 2687 ready 34 RT milljogtranslator ready 33 User shuttlexpress4 2682 ready 31 RT time ready 28 User tormach 2672 ready 26 User inihal 2671 ready 25 RT near ready 24 RT scale ready 23 RT lowpass ready 22 RT limit2 ready 21 RT sim_encoder ready 20 RT encoder ready >> 19 User mb2hal 2657 ready 17 User usbio 2656 ready 15 RT not ready 14 RT tormachltc ready 13 RT pwmgen ready 12 RT abs ready 11 RT estop_latch ready 10 RT stepgen ready 9 RT motmod ready 8 RT trivkins ready 7 User halui 2644 ready 5 User iocontrol 2642 ready
and I can see the hal variables showing up
19 float OUT 0 mb2hal.XDrive01.00.float 19 s32 OUT 0 mb2hal.XDrive01.00.int 19 float OUT 0 mb2hal.XDrive01.01.float 19 s32 OUT 0 mb2hal.XDrive01.01.int 19 u32 OUT 0x00000000 mb2hal.XDrive01.num_errors
now to make it work
I do want to write a custom VFD Driver for the Teco EV101 but figure using mb2hal would be quickest way to get a spindle going.
also have some Modbus Relays to use which for mb2hal should be simple to implement.
10 years 6 months ago #72693 by racedirector
Replied by racedirector on topic PathPilot and Modbus
I had to install libmodbus on my PathPilot install to get mb2hal to work properly. I'll go out and check what version I installed. Yes, mb2hal had to be in ~/tmc/bin as you found out. I run an Hitachi X200 VFD via mb2hal so it is possible.
10 years 6 months ago #72697 by Swapper
Replied by Swapper on topic PathPilot and Modbus
racedirector any chance you can share the config for the Hitachi X200 VFD ?
10 years 6 months ago - 10 years 6 months ago #72755 by racedirector
No problem, attached.
Used like this:
# Blacksheep Woodworks Addition for x200 VFD loadusr -Wn x200 mb2hal config=x200vfd.ini loadrt scale count=1 addf scale.0 servo-thread setp scale.0.gain .16666667 net spindle-speed-out scale.0.in motion.spindle-speed-out tormach.spindle-speed-out net x200-freq x200.frequency.00 <= scale.0.out net x200-run x200.run.00 <= motion.spindle-on net spindle-at-speed x200.at-speed.00 <= motion.spindle-at-speed setp x200.direction.00 0
I don't currently use all the definitions in the ini yet, got sidetracked getting PathPilot working :)
This line connects the spindle speed to the PathPilot display. Took me a while to figure that one out!
Cheers
Last edit: 10 years 6 months ago by racedirector. Reason: Added PathPilot specifics
Time to create page: 0.357 seconds
