Tool change .ngc brakes the ability to use "run from here"
7 years 3 months ago #138903
by Marcking
Replied by Marcking on topic Tool change .ngc brakes the ability to use "run from here"
Hello Guys, I'm having this same problem on a 2.7.14 version does someone find a solution?
Thanks!
Thanks!
7 years 3 months ago #138930
by emcPT
Replied by emcPT on topic Tool change .ngc brakes the ability to use "run from here"
The problem persists here. In fact is the only problem that we actually currently face.
The following user(s) said Thank You: Henk
7 years 3 months ago #138933
by Henk
Replied by Henk on topic Tool change .ngc brakes the ability to use "run from here"
Hi
We have the same issue on 2.7.14 on the milling machines, they use the manual toolchange function so hasn't really bothered us.
We have two lathes also running 2.7.14, but I don't recall having that issue on them.
Henk
Henk
7 years 3 months ago #138952
by Marcking
Wow! can't believe it, I have made some tests and found that not only remapping M6 code does the problem also remapping the T code too so I just made a call to the tool change macro instead and the problem persists(replaced Txx M6 with o<change> call).
This machine needs to make tool changes and it is very needed to some times running from a second, third and so on tool. Hope someone can give us a workaround?.
7 years 3 months ago #138965
by Henk
That explains why my lathes don't have that problem. My mill has remapped M6. The lathes not...
7 years 3 months ago #138969
by Marcking
I made a lathe retrofit weeks ago and worked almost fine, only problem was that I had to add an M01 before each tool change because when running the program with 4 tool changes the program skip the moving blocks and makes the next tool change(very crazy) but with an M01 before each change that worked around ja ja.
Time to create page: 0.199 seconds
