6i24-25 and 7i52S
7 years 5 months ago #134195 by PCW
Replied by PCW on topic 6i24-25 and 7i52S
I dont think there is a 5I24-25 project file so you need to change
the FPGA chip in the project properties
( select top level file in file pane, right click and select "design properties" )
7 years 5 months ago #134196 by gaston48
Replied by gaston48 on topic 6i24-25 and 7i52S
Yes find
device XC6SLX16 to device XC6SLX25 (not device XC6SLX25T) ?
7 years 5 months ago #134197 by PCW
Yes, change to XC6SLX25-FTG256
Also make sure the speed is 2. Some versions of ISE set the speed to 3 when you change the chip type so you need to change the type, close the properties pane, reopen the properties pane and change the speed.
7 years 5 months ago #134206 by gaston48
Perfect, thank you PCW, (and talla83 ...)
the card is flashed and with "readmid", all the inputs/outputs are good. :)
7 years 1 month ago #145081 by pgettings
Replied by pgettings on topic 6i24-25 and 7i52S
I also have a 6i24 card connected to a 7i52S. I tried the linked firmware file, but it appears to not be loading into my 6i24 card; linuxcnc reports finding a 5i24 card (33 MHz PCI clock, so that makes sense), but then reports all 72 I/O pins as being GPIOs. No encoder lines or step generator pins. Am I missing something, or do I have a different 6i24 that isn't supported by the firmware file? How would I check the model of 6i24? Thanks for any help.
7 years 1 month ago - 7 years 1 month ago #145083 by PCW
6I24s are normally setup to emulate a 5I24 and use 5I24 bit files
LinuxCNC cannot load the FPGA on cards with flash memory like the 5I24/6I24,
you must use the mesaflash utility and program the card with a
5I24_25_xxxx.bit or 5I24_16_xxxx.bitfile depending on the 6I24 card model.
Last edit: 7 years 1 month ago by PCW.
Time to create page: 0.307 seconds
