Deckel FP5 Gearbox Comp
4 years 3 months ago #246673 by gernoff
Replied by gernoff on topic Deckel FP5 Gearbox Comp
Thanks for the info Niko. I will try to look at your files and see if my feeble mind can wrap around the logic.........
I already have the Heidenhain EXE's. Picked up some EXE610c units same pinout and pin compatible with the installed scales. The FP5 already runs at 1 micron (.001mm) resolution. The 610c units allows both X5 and X10 interpolation so I can run at .0005mm. Do not really expects the accuracy to be any better but at the slower speed these giant machines run at I should not have to worry about missing pulses and might as well use the extra resolution. I hope it might improve the positioning accuracy when using the MPG.
4 years 3 months ago #246675 by Niko
Replied by Niko on topic Deckel FP5 Gearbox Comp
Just to save you some time .
The rotary switch is sent to the tumbler_decode component which holds the look up table for speeds and gearbox fork positions . That would've been unpleasant in ladder . After the desired fork positions are defined and run spindle given the PLC selects the right gear . Actual fork position is given in the nets named gear-block1/2/3-back/mid/front the desired are named block1/2/3-back/mid/front-in . Ladder inside is pretty straightforward . Spindle jerk is pulsed(motor started through resistors) to match the gear teeth, but in your case it'll just be jog from the drive . That way you don't have to multiplex drive enable and analog values .
4 years 3 months ago #246717 by gernoff
Are you using the original Deckel control console? Did you swap out the spindle speed rotary switch, rewire it or is it already set up to be de-muxed?
4 years 3 months ago #246779 by Niko
The machine was delivered to me without the operator panel . Just the cable sticking out . I designed a similar one which acommodates the PC and some of the mesa boards . The switch I put in has 23 positions which are converted to a 5 bit binary number on a seperate board . Would be absolutely wasteful to use 23 digital inputs .
4 years 3 months ago #246811 by gernoff
Thanks for the information. I will eventually be getting into my console to look at the selector switch wiring. I will replace them with 5 bit encoders if necessary.
4 years 3 months ago #246819 by Niko
https://www.indiastudychannel.com/attachments/Resources/137809-15246-1.bmp
That's roughly the schematic of mine . Absolutely easy and simple to build even on a proto board.
Time to create page: 0.361 seconds
