Singularity ... again
3 years 2 weeks ago - 3 years 2 weeks ago #282943 by bkt
Replied by bkt on topic Singularity ... again
and in your opinion is possible perform the switch, chage singularity konst value with custom hal pin on kinematics file, than switch again ro world without any issue? (ok may be need acc. limit3 because eblow change at max acc to new point ....
TESTED:
you go in joint mode on "zero position of machinery/robot" than perform switch of singularity and return in world mode again .... these for 100 time for sure ... tested on real robot .... in my case (not little robot) we can positioning with an error of 0.05mm whitout particular issue when you perform the switch of singularity .... obviusly the tiltening because kins zero pos remain ... i use these kins for scara .... note DX pin ... switch from eBlow to right and eBlow to left direction ..
code:
/***************************************************************** * Description: inv_scarakins.c *   Kinematics for scara typed robots *   Set the params using HAL to fit your robot * *   Derived from a work by Sagar Behere *   Bkt add bit pin for perform inversion of eBlow position during motion *       WARNING USAGE: before perform the infersion of geometry go to J0=0deg ,J1=0deg and J2=0deg * ****************************************************************************************************** *       WARNING ** GO TO ZERO MACHINE POSITION BEFORE INVERT GEOMETRY - IF NOT CAN DAMAGE ** WARNING * ****************************************************************************************************** * * Author: BKT * License: GPL Version 2 * System: Linux * * Copyright (c) 2023 All rights reserved. * * Last change: ******************************************************************* */ #include "posemath.h" #include "rtapi_math.h" #include "kinematics.h"             /* decls for kinematicsForward, etc. */ #include "rtapi.h"        /* RTAPI realtime OS API */ #include "rtapi_app.h"        /* RTAPI realtime module decls */ #include "hal.h" struct scara_data {     hal_float_t *d1, *d2, *d3, *d4, *d5, *d6;     hal_bit_t   *dx; } *haldata = 0; /* key dimensions    joint[0] = Entire arm rotates around a vertical axis at its inner end         which is attached to the earth.  A value of zero means the         inner arm is pointing along the X axis.    D1 = Vertical distance from the ground plane to the center of the inner         arm.    D2 = Horizontal distance between joint[0] axis and joint[1] axis, ie.         the length of the inner arm.    joint[1] = Outer arm rotates around a vertical axis at its inner end         which is attached to the outer end of the inner arm.  A         value of zero means the outer arm is parallel to the         inner arm (and extending outward).    D3 = Vertical distance from the center of the inner arm to the center         of the outer arm.  May be positive or negative depending         on the structure of the robot.    joint[2] = End effector slides along a vertical axis at the outer end         of the outer arm.  A value of zero means the end effector         is at the same height as the center of the outer arm, and         positive values mean downward movement.    D4 = Horizontal distance between joint[1] axis and joint[2] axis, ie.         the length of the outer arm    joint[3] = End effector rotates around the same vertical axis that it         slides along.  A value of zero means that the tooltip (if         offset from the axis) is pointing in the same direction         as the centerline of the outer arm.    D5 = Vertical distance from the end effector to the tooltip.  Positive         means the tooltip is lower than the end effector, and is         the normal case.    D6 = Horizontal distance from the centerline of the end effector (and         the joints 2 and 3 axis) and the tooltip.  Zero means the         tooltip is on the centerline.  Non-zero values should be         positive, if negative they introduce a 180 degree offset         on the value of joint[3].    DX = kinematics identity flag. If dx=0 scara put elbow to left, if dx=1 put elbow to right */ #define D1 (*(haldata->d1)) #define D2 (*(haldata->d2)) #define D3 (*(haldata->d3)) #define D4 (*(haldata->d4)) #define D5 (*(haldata->d5)) #define D6 (*(haldata->d6)) #define DX (*(haldata->dx)) /* joint[0], joint[1] and joint[3] are in degrees and joint[2] is in length units */ int kinematicsForward(const double * joint,                       EmcPose * world,                       const KINEMATICS_FORWARD_FLAGS * fflags,                       KINEMATICS_INVERSE_FLAGS * iflags) {     double a0, a1, a3;     double x, y, z, c; /* convert joint angles to radians for sin() and cos() */     a0 = joint[0] * ( PM_PI / 180 );     a1 = joint[1] * ( PM_PI / 180 );     a3 = joint[3] * ( PM_PI / 180 );     //*iflags = DX; /* convert angles into world coords */     a1 = a1 + a0;     a3 = a3 + a1;     x = D2*cos(a0) + D4*cos(a1) + D6*cos(a3);     y = D2*sin(a0) + D4*sin(a1) + D6*sin(a3);     z = D1 + D3 - joint[2] - D5;     c = a3;          if(DX == 0){         *iflags = 0;         if (joint[1] < 90)         *iflags = 1;     } else {         *iflags = 1;         if (joint[1] < 180)         *iflags = 0;     }     //*iflags = 0;     //if (joint[1] < 90)     //*iflags = 1;          world->tran.x = x;     world->tran.y = y;     world->tran.z = z;     world->c = c * 180 / PM_PI;          world->a = joint[4];     world->b = joint[5];          return (0); } int kinematicsInverse(const EmcPose * world,                       double * joint,                       const KINEMATICS_INVERSE_FLAGS * iflags,                       KINEMATICS_FORWARD_FLAGS * fflags) {     double a3;     double q0, q1;     double xt, yt, rsq, cc;     double x, y, z, c;     x = world->tran.x;     y = world->tran.y;     z = world->tran.z;     c = world->c;     /* convert degrees to radians */     a3 = c * ( PM_PI / 180 );     /* center of end effector (correct for D6) */     xt = x - D6*cos(a3);     yt = y - D6*sin(a3);     /* horizontal distance (squared) from end effector centerline     to main column centerline */     rsq = xt*xt + yt*yt;     /* joint 1 angle needed to make arm length match sqrt(rsq) */     cc = (rsq - D2*D2 - D4*D4) / (2*D2*D4);     if(cc < -1) cc = -1;     if(cc > 1) cc = 1;     q1 = acos(cc);     //if (*iflags == 1){q1 = -q1;}     //else {q1 = q1;}     if (*iflags)         q1 = -q1;     /* angle to end effector */     q0 = atan2(yt, xt);     /* end effector coords in inner arm coord system */     xt = D2 + D4*cos(q1);     yt = D4*sin(q1);     /* inner arm angle */     q0 = q0 - atan2(yt, xt);     /* q0 and q1 are still in radians. convert them to degrees */     q0 = q0 * (180 / PM_PI);     q1 = q1 * (180 / PM_PI);     joint[0] = q0;     joint[1] = q1;     joint[2] = D1 + D3 - D5 - z;     joint[3] = c - ( q0 + q1);     joint[4] = world->a;     joint[5] = world->b;     if (DX == 1){*fflags = 1;}     else {*fflags = 0;}     //*fflags = DX;     //*fflags = 0;     return (0); } int kinematicsHome(EmcPose * world,                    double * joint,                    KINEMATICS_FORWARD_FLAGS * fflags,                    KINEMATICS_INVERSE_FLAGS * iflags) {   /* use joints, set world */   return kinematicsForward(joint, world, fflags, iflags); } KINEMATICS_TYPE kinematicsType() {   return KINEMATICS_BOTH; } #define DEFAULT_D1 490 #define DEFAULT_D2 340 #define DEFAULT_D3  50 #define DEFAULT_D4 250 #define DEFAULT_D5  50 #define DEFAULT_D6  50 #define DEFAULT_DX  0 EXPORT_SYMBOL(kinematicsType); EXPORT_SYMBOL(kinematicsForward); EXPORT_SYMBOL(kinematicsInverse); EXPORT_SYMBOL(kinematicsHome); MODULE_LICENSE("GPL"); int comp_id; int rtapi_app_main(void) {     int res=0;          comp_id = hal_init("gc_scarakins");     if (comp_id < 0) return comp_id;          haldata = hal_malloc(sizeof(*haldata));     if (!haldata) goto error;     if((res = hal_pin_float_new("gc_scarakins.D1", HAL_IO, &;(haldata->d1), comp_id)) < 0) goto error;     if((res = hal_pin_float_new("gc_scarakins.D2", HAL_IO, &;(haldata->d2), comp_id)) < 0) goto error;     if((res = hal_pin_float_new("gc_scarakins.D3", HAL_IO, &;(haldata->d3), comp_id)) < 0) goto error;     if((res = hal_pin_float_new("gc_scarakins.D4", HAL_IO, &;(haldata->d4), comp_id)) < 0) goto error;     if((res = hal_pin_float_new("gc_scarakins.D5", HAL_IO, &;(haldata->d5), comp_id)) < 0) goto error;     if((res = hal_pin_float_new("gc_scarakins.D6", HAL_IO, &;(haldata->d6), comp_id)) < 0) goto error;     if((res = hal_pin_bit_new("gc_scarakins.DX", HAL_IN, &;(haldata->dx), comp_id)) < 0) goto error;          D1 = DEFAULT_D1;     D2 = DEFAULT_D2;     D3 = DEFAULT_D3;     D4 = DEFAULT_D4;     D5 = DEFAULT_D5;     D6 = DEFAULT_D6;     DX = DEFAULT_DX;     hal_ready(comp_id);     return 0;      error:     hal_exit(comp_id);     return res; } void rtapi_app_exit(void) { hal_exit(comp_id); }
Last edit: 3 years 2 weeks ago by bkt.
3 years 2 weeks ago #282988 by bkt
See some video where that inversion appear durin J0 motion and J1 stop motion .... with J0 and J1 to 0deg .... not try if possible here on linuxcnc ....
other stuck is mechanical vibration near world mode zero position .... or when we reach maximum radius in world mode ... these because cos 0.1, cos 0.01, cos 0.001 is too little and become too mutch segment to moove in little real space for TP .... so need some function for limit vel and acc during these "spaces" ....
these is desired result ... and I test only in MANUAL mode
About inverted kins, is possible to use switchkins of dgarret, for
  1. run gcode with desired starting kins geometry and perform some gcode row in WORLD mode
  2. switchkins in gcode for put machine in exact position and exact geometry everytime you need to invert geometry, using JOINT mode
  3. invert kins in JOINT mode
  4. switchkins to WORLD mode and perform some other row of gcode in WORLD mode
Think is possible repeat from 1 to 4 point many time without error ...
Time to create page: 0.295 seconds
