- Thank you received: 139
caxis.comp status
- smc.collins
2 years 9 months ago #291975
by smc.collins
Replied by smc.collins on topic caxis.comp - problems
Can you see the position cmd and position actual in degreees ??? See if anything odf there. Set a hal scope trugger for the index pulse, see if it's got noisy signal ? If index was triggered i could see it dumping the known position and rolling over unexpectedly
2 years 9 months ago #291983
by spumco
Replied by spumco on topic caxis.comp - problems
@Tommy,
Re-reading the PID manual, deadband should be set slightly greater than 1/2 count to stop hunting. Your example is (I suspect) referencing a linear axis where you've got a very high count-per-unit (like thousands of counts per mm or inch). Just like my X/Z axes with 1um encoders where I've got ~25400 counts/inch.
My subspindle is a direct-drive rotary axis where units = degrees. So I've got ~27 counts per degree; significantly coarser feedback per unit.
The encoder signal is output from the drive, and I've got it set as high a resolution as possible.
@Aciera,
I tried the PID autotune a couple times on my Z-axis a while ago and the results were just dumb. While I may give it a try, I haven't read a single report on the forum where someone was pleased with the results.
@smc.collins,
I have the pos-cmd and pos-fb up in halshow, but haven't yet scoped them. Nothing odd or way off during a programmed back-and-forth move. It homes to index fine and the counts/position/velocity all look like they should even when it flips out. Doesn't lose track of where it is.
I'm going to try connecting it like an open-loop stepper tonight - connect stepgen pos-fb to pid.b.feedback and joint motor-pos-fb. That should help me see if my issue is with the PID or not.
@Aciera,
@smc.collins,
2 years 9 months ago #291994
by spumco
2 years 9 months ago #292012
by spumco
2 years 9 months ago #292014
by pawel77
Replied by pawel77 on topic caxis.comp - problems
2 years 9 months ago #292019
by spumco
@pawal77,
Thank you for the comment and consideration. Unfortunately I'm having a hard time translating your comment/suggestion in to something concrete I can or should change in the above configuration.
Do you have a specific suggestion for a specific component or value I can test? Something like "instead of connecting pinN to pinY, connect pinZ to pinY and set XYZ value to 1234"
Time to create page: 0.270 seconds
