Fehlmann Picomax 100 Retrofit
4 years 3 months ago #248541 by Kevin_Pawlus
Looking good :)
Is that a Siemens DC motor?
It looks very much like what I have on my machine, I hope I don't need to replace it.
4 years 3 months ago #248578 by anfänger
It's a DC motor but not Siemens and I am replacing it I have a 3 Phase servo here. Which I hope will fit nicely.
I had some trouble with the drive unit and needed an encoder to run with linuxcnc. So I decided to change it.
4 years 3 months ago - 4 years 3 months ago #248691 by anfänger
Today was motor swapping dayToday was motor swapping day
Last edit: 4 years 3 months ago by anfänger.
The following user(s) said Thank You: arvidb
4 years 3 months ago #248692 by anfänger
I kind of have trouble editing and pposting pictures.
anyway the motor is swapped. and with no running cnc I realized hi nice big lathes are
[img
nest is to swap the driver. and give it a test.
3 years 11 months ago #257475 by anfänger
Long time not progress here but I managed to mount the VFD into the cabinet:
[img
rest ist to wire it up. But there is the question. Using the analog control or using Ethercat?
Ethercat would ease the wiring quite a bit. But how to manage?
I have no clue yet. And can I dress the Mesa Card and the Ethercat device fro the same ethernet port? DO I need a switch? I can I connect the VFD to the computer and the Mesa board to the 2nd port of the VFD?
This would be great, but I am afraid the world is not that simple...
3 years 5 months ago - 3 years 5 months ago #270877 by anfänger
long time no see... the reason was simple I didn't make big progress.
but now some mentionable steps are done...
The spindle motor and VFD ist wired with own contactor an breaker, ready to get powered on for the first time and get its parameter.
removed some bug in the wiring, this took some time.
I switched the old column control (was not working) to a new solid state reversing contactor and let linuxcnc control the brake in hal
and now it's moving by it's own power:
youtube.com/shorts/2_kBhY5CB0k
Started the Drives for the first time, x is moving right away and giving ne a following error. Don't know how to fix it yet.
Last edit: 3 years 5 months ago by anfänger.
Time to create page: 1.992 seconds
