Burgmaster CNC
3 months 3 weeks ago #347639 by spumco
Replied by spumco on topic Burgmaster CNC
Before any other evaluation, check the spindle bearings to see if they are capable of handling real radial loads.
Manual or semi-auto drill/tap machines may not have angular contact (or tapered roller) bearings as they are only intended for axial loads.  It would be rather a shame to discover you can't do any reasonable side-milling without a major redesign of the spindle.
I've no idea what the situation is in your country, but if used machine tools are that expensive I'd think a self-built thing from scratch would be better than that Burgmaster.
The following user(s) said Thank You: tommylight, timo
Time to create page: 0.220 seconds
