jeffgar2000@gmail.com wrote: Never mind. I edited an xyza set that I created with the wizard and turned it into an xyuv. Now the gui knows how to talk to the hardware.
Is it working properly now?
Depending on the LinuxCNC version you are using you might need sections in the INI fle for [AXIS_0] through to [AXIS_7] but only the settings in [AXIS_0], [AXIS_1], [AXIS_6] and [AXIS_7] will be used.
The important INI file entries for a foam cutter are
[DISPLAY]
GEOMETRY = XY;UV
FOAM = 1
[TRAJ]
COORDINATES = X Y U V
You may need JOINTS = 8
(If you are using the development branch "Master" then it would be JOINTS = 4 as the need for dummy placeholder joints has been removed)
