- Thank you received: 486
Would I be better off with a 100 slot disc (mine is 64 slot)?
You might well be.
I have a 120 hole disc on mine, which was the limit of the number of 3mm holes with 3mm spacing I could get on the disc.
I prevoiusly had a 60 hole version and this is much smoother.
I just have an A and a Z, no B. I don't want to do rigid tapping and as all threading is done in the same direction, B was no advantage.
I have read some ware "The advantages of using both A and B are increased noise immunity and increased resolution"
cmorley wrote: Clive
You are using master if you have U or V in a stepconf config.
But I just pushed fixes to that problem.
Chris M
