Forum Header
Z Stepper won't run
11 years 1 week ago #64019 by bwg
Z Stepper won't run was created by bwg
Have new setup with tb6560. I thought I had everything going after finding the pin outs for the TB 6560, but at the time I only had X and Y hooked up. They work fine but Z won't work. When I try to test the Z axis, the X stepper is apparantly energized it sits there and buzzes. When I text X and Y they appear to be fine. I tried to add a zenable line in hal custom file but that only generates an error.
Does anyone have any guidance. I'm losing my mind
11 years 1 week ago #64031 by Rick G
11 years 1 week ago #64038 by cncbasher
Replied by cncbasher on topic Z Stepper won't run
it's noting more than finding the variant of the parallel port that works ,
make a list of the pins that work ,and are correct , and it should be easy to relate the others , beware of amp enable some boards wont work if that is not connected , but it seems you have some movement
so just leave that pin till last . post what you have and it should not take long to figure the rest
is their any version numbers on the pcb also , they use the colour of the pcb to denote versions in some , so post a picture of the board , or if you have a connection sheet as a pdf attach that here
look through the posts you'll find more than one version of configs .
11 years 1 week ago #64049 by bwg
Replied by bwg on topic Z Stepper won't run
I have a feeling that Amplifier Enable switch is contributing to this situation. But I need to learn more about this software to iron it out. For instance, I have seen these configuration files before. But I don't really know how to use them. Should I just plug them into the folder for my linuxcnc configuration and bypass stepconf program? Also, I notice that this rf-30 does not mention amplifier enable at all.
I guess it mainly boils down to my studying up on hal configs. The documentation seems a little sparse but I probably am just looking in the wrong place.
11 years 1 week ago #64060 by andypugh
Replied by andypugh on topic Z Stepper won't run
bwg wrote: Should I just plug them into the folder for my linuxcnc configuration and bypass stepconf program?
I would suggest keeping the stepconf-produced configuration and trying to see in what way the Z axis parts differs from the others.
The right place is here, the problem is rather the reverse of sparseness, there is so much documentation it can be hard to find the right parts.
www.linuxcnc.org/docs/html/
11 years 1 week ago #64077 by cncbasher
rather then fumble in the dark , give me information on the controller you have , and any detaills that came with it
and i'll help sort the weeds
and let me know what config you have tried , and what works or not , will help
Time to create page: 0.173 seconds
