Forum Header
Z Stepper won't run
11 years 1 week ago #64108 by bwg
Replied by bwg on topic Z Stepper won't run
The board is 3 axis Blue Board. The only id is "30695S" I have attached a picture.
Here is how I configured the board via Stepconf.
Pin:
1 X Step
2 Y Enable
3 Y Direction
4 Z Direction
5 Z Step
6 Amp Enable
7 X Dirction
8 Y Step
9 Spindle Motor
10 Input 0
11 Input 1
12 Input 2
13 Input 3
14 X Enable
15 Unused
16 Out 1
17 Out 2
This config allows X and Y axis to work both in Stepconf and Axis. When I try Z in Stepconf the only that happens is that the motors on X and Y are buzzing (shaking) but the Z motor does not. Nothing else moves when testing Z.
btw I changed the motors around and they all work if used in X or Y.
11 years 1 week ago #64113 by cncbasher
Replied by cncbasher on topic Z Stepper won't run
try a new config with the following
pin2 xstep
pin3 xdir
pin4 ystep
pin5 ydir
pin6 zstep
pin7 zdir
just in case
it's trying a few combinations that we know were used on these boards
11 years 1 week ago #64114 by bwg
I will try those, but what about the other pins. Should I config them as unused? Or should I set those up by hand?
11 years 1 week ago #64115 by bwg
pin2 xstep
pin3 xdir
pin4 ystep
pin5 ydir
pin6 zstep
pin7 zdir
No good. Nothing works.
11 years 1 week ago #64141 by andypugh
Replied by andypugh on topic Z Stepper won't run
It might be worth tracing the actual tracks on the PCB to the stepper driver chips.
11 years 1 week ago #64143 by bwg
I have been reading some other threads and notice that the "amplifier enable" might have a lot to do with this situation. I am beginning to think that since there is only the amplifier enable switch that doesn't appear to be tied to any specific channel that maybe "amp enable" needs to change state before moving from one axis to another. I don't know if that makes any sense.
This all leads me to believe that the answer will lie somewhere in HAL config. If thats the case I think I'll need a year or two to learn that language before I'm able to do anything with it. :(
In the meantime I will try ringing out the leads and see what I can discover
Tks again
Bruce
Time to create page: 0.219 seconds
