nicokid wrote: Unfortunately there is no way to include the MDI_COMMAND in a different place from the [HALUI] section on the INI file. I did not understand why this command does not work or it probably does not do what I think:
Code:loadusr halui -ini /path/to/inifile.ini
Right now I have downloaded the latest version of git away LinuxCNC and I started to look into the sources of stepconf. First I almost completely adapted the glade files to Gtk3. Then I think I could add a window to stepconf with a text box to enter inside the custom MDI_COMMAND.
Andy has already hinted at it, but you are possibly missing the purpose of stepconf.
It is not a menu based GUI editor for Linuxcnc configurations.
It is a tool to quickly enable a working configuration to be produced, which can be fine tuned.
Once you have a working configuration, you do not let stepconf anywhere near it.
If you want to add anything, MDI command or whatever, you open the ini or hal file in an editor.
NB. If you change files to glade/gtk 3, you will be at odds with all the other parts of linuxcnc, since AFAIK there are no gladevcp glade3 widgets, which is why glade2 is used.
)Please Log in or Create an account to join the conversation.
