Forum Header
start in linuxCNC
10 years 7 months ago #72469 by aleksamc
start in linuxCNC was created by aleksamc
Hello all,
I’ve decided to change mach3 to linuxCNC and i can’t configure it.
I have made all configs except pin «Enable» because I haven’t found it in the list for my PIN_14, I use Russian version and I don’t understand how it was translated. I suppose because of that my motors not running in test mode in config – but they are on break.
When I turn on my CNC, stepper motors have breaks deactivated.
Can anybody show me photo of list for pins with pin Enable on english? And how to change language of linuxCNC to English?
10 years 7 months ago #72472 by andypugh
Replied by andypugh on topic start in linuxCNC
The translations are all here:
github.com/LinuxCNC/linuxcnc/blob/master/src/po/ru.po
#: src/emc/usr_intf/stepconf/stepconf.py:156 msgid "Amplifier Enable" msgstr "Включить усилитель"
Does that help?
However, you should be able to simply import the Mach3 XML file directly into Stepconf. Did you try that?
10 years 7 months ago #72515 by aleksamc
Replied by aleksamc on topic start in linuxCNC
I have imported mach3.xml into linuxcnc but it synchronized not all values I have added them manually. More over I've tried "Amplifier Enable" but it's wasn't running.
I will tried to set dimensions one more time later because my CNC now work on mach3 on other computer.
I have such sets for pins now:
inputs: Outputs
1: - 10: Estop input
2: Y step parport: 0x378
3: Y dir output pinout preset: Sherline
4: Z step
5: Z dir
6: A step
7: A dir
8: X step
9: X dir
14: Amplifier enable
Is something wrong with this configuration?
10 years 7 months ago #72517 by andypugh
Is pin 14 active-low, active-high, or charge-pump (ie, does it need to toggle continuously to enable the drive?)
10 years 7 months ago #72518 by aleksamc
Pin 14 is active hight - it enables drivers to work. It should be continuously toggled.
Very interesting is that when I tune axis in stepconf - drivers for stepper motors are activated but not running no one. And when I turn on emc2 to work on program, I turn on the machine (F1 and F2) but drivers are deactivated.
10 years 7 months ago #72519 by andypugh
Try inverting the enable output (there is a check-box next to the pin definition in Stepconf)
The "Test Axis" screen does not do anything to enable/disable the drives, so this points to the drives being actually disabled by LinuxCNC, ie the pin is operating the wrong way.
Time to create page: 0.103 seconds
