Forum Header
start in linuxCNC
10 years 7 months ago #72520 by aleksamc
Replied by aleksamc on topic start in linuxCNC
Thanks a lot. I will try.
10 years 6 months ago #72684 by aleksamc
I have tried this and evrything work OK. But problem was not with Amplifier but with limits - they are not tunded. I have turned them off and currently I work without limits.
Where can I look states of parallel port?
10 years 6 months ago #72687 by andypugh
Replied by andypugh on topic start in linuxCNC
[quote="aleksamc" post=72684Where can I look states of parallel port?[/quote]
If you are using the Axis GUI then you can use Machine->Halmeter and set up a halmeter for each parport input.
Or you can go to Machine->Show Hal Configuration and use the "Watch" tab then select the parport pins.
Or you can use this: wiki.linuxcnc.org/cgi-bin/wiki.pl?Parallel_Port_Tester though hooking that up to a running config is a bit tricky.
The following user(s) said Thank You: aleksamc
Time to create page: 0.129 seconds
