So I finally have this one figured out. I thought I would post it so I can maybe help someone else in the future. So when I put all my settings in stepconf and test in stepconf the actual scale is doubled when I measure it. The ini file is exact settings. So I finally gave it a whirl in linuxcnc and what do you know it all works out right with the scale. So the problem is with stepconf , it doubles when it runs. It sets it up fine in ini file . So you have to actual test your results in Linux Cnc , the stepconf file is useless for testing for acurracy.
Thanks for your posts and help, I hope someone finds this usefull
