- Thank you received: 784
Todd Zuercher wrote: We are certainly not saying that you can't use those drives, they sound like great drives, and they will work perfectly well with linuxcnc. I believe that if you set the acceleration profile to only a small jerk limitation, and have the drives max acceleration a bit higher than the max defined in Linuxcnc, you will probably get very good results with them. The jerk limiting in the drive could take the edge of the accelerations of Linuxcnc without introducing a significant amount of following error, and the drive would quickly catch up to where it should be. You just may need to do a little experimentation to find the optimal settings.
Why does everyone freak out when they hear the words "following error". It is an ever present reality. The trick to tuning a machine is to minimize them while optimizing for best performance, and remaining within tolerances. It is always a balancing act of compromise.
