Forum Header
The Express pci parport card address .What?
10 years 2 months ago #79161 by 819132306
Whether the BIOS-related?
10 years 2 months ago #79162 by 819132306
Yes, I'm for this headache.
My computer is X200T.
BOIS version has no parallel port option
BOIS version needs to be upgraded.
Lspci-v can directly display all devices, including BOIS is not recognized?
My English is rubbish rely on translation software, do not know if there are any ambiguities
10 years 2 months ago #79167 by tommylight
That is a Lenovo X200 right???
You can not use that laptop to control an actual machine due to way to many power saving options that can not be disabled in BIOS.
I had several X220 and they are magnificent in any way except for actually controlling a machine.
You can use older T40/T41/T42/T43 models or X60 with a docking station (paraport is on the dock), and they are very usable, if you set the latency above 35000.
As for lenovo, install the sim version of linuxcnc so you can check and if needed correct the gcode before transferring it to the machine.
10 years 2 months ago #79181 by 819132306
yes, x200t,
BOIS version has no parallel port option.
do i update the bois,
this netbook latency 15000
10 years 2 months ago #79182 by 819132306
I did not install the parallel port driver is not required to drive with the linuxcnc port?
10 years 2 months ago #79183 by tommylight
You can update the BIOS but i do not think it will help, and latency on my X220 ( i had several of them ) was over 2000000 (2 milion).
If you can get a latency of 15000 you are all good, but not with a paraport, use a MESA ethernet card like 7i92E, that would be perfect.
Time to create page: 0.495 seconds
